Go to Post I'd like to think that I'm at least a sometimes useful mentor. - artdutra04 [more]
Unread 08-01-2012, 20:38
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
Ball weights
Measure the weight of the three balls you got in you KoP and post the weight of each in this thread.
So that every one can get a idea of the variations in weight that they have.
Unread 08-01-2012, 20:46
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: Ball weights
Each ball weighs approximately 0.7 lbs.
So 3*0.7= 2.1 lbs.
Unread 09-01-2012, 18:12
FRC #1818
Re: Ball weights
305.1 g
302.1 g
303.2 g
So currently I see a 1% difference in weight. At 50 feet that might be a 6inch difference in distance. If other people add their number we will have data that has statistic meaning. My observations here are meaningless because 3 is not a meaningful sample size.
Unread 09-01-2012, 23:12
dmalone dmalone is offline
FRC #1684 (Chimeras)
dmalone will become famous soon enough
Re: Ball weights
Using the 3 ball weights posted below and our 3 weights I ran a 1000 piece random sample in Mintab based upon the average & standard deviation of the 6 to estimate the population....
Stem-and-leaf of Weight l N = 1000
Leaf Unit = 0.0010
2 61 07
16 62 02446666777889
66 63 00001111222333334444555555566667777777788888899999
236 64 00000000000111111111111112222222222233333333333333 34444+
(289) 65 00000000000000001111111111111111111112222222222222 22222+
475 66 00000000000000000000000001111111111111111111111111 22222+
220 67 00000000000000000000011111111111111122222222222222 22222+
65 68 000000111111122222333333344444455556666667777789
17 69 000122244467889
2 70 56
Summary:
Min ~ .610 lbs
Mean ~ .651 lbs
Max ~ .706 lbs
More than 6 samples will improve the estimate of the population however it looks fairly tight...
Unread 10-01-2012, 11:38
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Re: Ball weights
.290 kg
.294 kg
Sorry... only had a triple beam balance available when I did my measurements. Also only had 2 balls available to me... have to find that last one...
