Go to Post Our job is to play the game that the GDC gave us, not the one we think they should have given us. - Herodotus [more]
Unread 08-01-2012, 21:53
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Official 2012 Motors Models and Specs Thread
I should have been clearer. The point in contention is this: Timz3082 is claiming* that the motor portion of the PG71 (am-0914) is the same motor as the 9015 (am-0912). I was asking where he got that information.
* see post #5: "That is with the gearbox, without it is 180 W"
Ahh, I see we are on the same page.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 09-01-2012, 01:36
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Does anyone know which motors are back-drivable and which motors are not?
Also are there any motor curves up yet? The page on the FIRST website does not have this.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 09-01-2012, 02:13
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Originally Posted by Andy Baker View Post
These numbers, posted by me on the AM website two days ago, are not correct. They have been updated to much more realistic, and larger numbers. We at AndyMark are changing these numbers a bit after some further testing this weekend. Sorry about this change. Please check our PG71 web page for any further updated information.
Here is more to the story.
When I was updating the web page for this motor on Friday, getting it ready for Saturday's kickoff, I saw that the stall torque was listed at 11 amps. This is information we got from the manufacturer. So, I called Mark, who was out at Manchester for kickoff to see what was up with this. He created and interpreted the performance numbers a few weeks ago, and listed the stall torque at 11 amps. We both thought about this some more and agreed that was waaaaay too low. He got home today and did a bench test that repeatedly performed at these numbers below. This test was ran with a 12.8 volt battery providing voltage directly to the motor. The stall torque is 23 ft-lbf, and the max current reading is 28.6 amps. We believe this translates to approximately 350 watts as the max power for the motor.
Tested at 12.8 volts
23 ft-lbf max torque at stall
28.6 amps pulled at stall
Estimated 350 watts of power
Here is Mark's setup. He had a force gauge measuring an arm's pull at exactly 1 foot away from the motor. The force gauge showed 23 lbs of force and the amp meter showed 28.6 amps. It was a simple setup, and we ran it about 10 times. The numbers were consistent. These numbers make much better sense to me compared to the "11 amp stall torque" numbers I posted on Saturday.
Again, sorry for these erroneous numbers yesterday, and please check out the PG71 website for future updates.
Sincerely,
Andy Baker
I don't know if I'm doing this right (actually, I'm pretty sure I am), but if you input 28.6 Amps at 12.8 Volts, that's equivalent to 366 watts of electrical power being put into the system.
350 watts of output power translates to >90% efficiency for a 12V motor, something that is ridiculously high.
Or, maybe I'm reading this wrong, and you're simply stating that it can pull about 350 watts of power, and not the output power... I'm confusing myself.
In the retest, was the torque due to the arms weight accounted for?
Attending: MN Duluth Regional
Unread 09-01-2012, 02:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Regarding the Automotive Recycler's Association motor deal, I found this press release: http://arav3.timberlakepublishing.co...p?Display=1476
My question is, can we simply buy and legally use any motor from a car rather than obtaining it through this route? If not,I think it's dumb that a piece of paper from a junkyard is the difference between a motor being legal and not.
Unread 09-01-2012, 04:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I can't believe we'd be allowed to use any motor at all. I'm looking forward to more info too. There has to be a reasonable limitation on what can be supplied.
Unread 09-01-2012, 08:41
See notes embedded in red:
Originally Posted by theprgramerdude View Post
I don't know if I'm doing this right (actually, I'm pretty sure I am), but if you input 28.6 Amps at 12.8 Volts, that's equivalent to 366 watts of electrical power being put into the system. Yes, that's how you would calculate the electrical power into the motor at stall. There is zero power output at stall.
350 watts of output power translates to >90% efficiency for a 12V motor, something that is ridiculously high. There is no mechanical power output at stall. You can't divide the 350 by the 366.
Or, maybe I'm reading this wrong, and you're simply stating that it can pull about 350 watts of power, and not the output power. Power rating should be the mechanical output power. See this post for how it's calculated.
Unread 09-01-2012, 09:16
You can use this to do all your motor calculations if you want to.
It now supports the following 2012 motors:
CIM
FP0673
FP2719
FP9012
FP9015
RS395
RS540 (not legal for 2012 but included)
RS550
RS775-12
RS775-18
am-0912
am-0914
DensoL
DensoR
Denso AE235100-0160
Unread 10-01-2012, 10:19
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Motor curves are linked on this page. Currently, the PDF file is here, but the filename appears to be changing with each revision.
FRC 766, 2015-, Mentor
Unread 10-01-2012, 10:43
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Ether- do the specs on that PDF look kosher to you? I trust your experience far more than FIRST spec sheets!
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 10-01-2012, 12:30
rbrown1 rbrown1 is offline
AKA: Rex Brown
FRC #1730 (Team Driven)
rbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant future
Maybe someone can help me. The Fisher Price motor we have in the kit supplied this year is a 00968-9013. Is there any motor data for this motor available?
Unread 10-01-2012, 12:36
The only changes from the initial revision are as follows:
1) corrected typo in Line1. Was "am-9012". Now is "am-0912"
2) corrected typo in Line2. Was "am-9014". Now is "am-0914"
3) changed data in Line2. Was/Is: 18.28/69.07 1309.4/4416 75/84 1.2/1.2 11.3/28.6
The new data is misleading. The Stall Torque and Stall Current are reported at 12.8 volts (and this is not indicated in the chart).
To create motor curves, use (12/12.8)*4416 = 4140 oz-in stall, and (12/12.8)*28.6 = 26.8 amps
Also, the power at 12 volts should be 64.3 watts. See post#10 in this thread.
Unread 10-01-2012, 12:46
Actually, there are a lot of folks here on CD with far more FRC-specific experience. But I have checked FRC's 2012 chart against data I had from past years and the only major error I found so far was the am-0914 data in Line2, which has now been corrected*.
On an earlier thread, Richard indicated he would perform dyno tests on the kit motors and report the results this week. When that data is available, I will incorporate it into the motor calculator.
*edit: but see caveat in post 26 of this thread
Unread 10-01-2012, 13:05
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Does anyone know why the stall current for the left handed Denso motor is higher than the stall current for the right handed one? If they are just flipped versions of each other shouldn't they be the same?
Unread 10-01-2012, 17:39
A Team Update has just been issued which de-lists the FP2719 and adds the FP9013 as an acceptable motor for 2012.
I would assume that an update to the 2012 motor specs chart* would follow shortly.
* click on the link labeled "data on the motors" on this web page.
Unread 10-01-2012, 20:52
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Driver side window motors are often built heavy-duty since the driver's window gets more use than the passenger window. They are not the same motors.
At least that's how I understand it.
Dr. Bob
Chairman's award is not about building a robot. Every team builds a robot.
