Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Unread 10-01-2012, 12:37
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Team 3489's Catapult Prototype
Inspired by Team Titanium, Category 5 decided to try a catapult, scavenging parts from our 2011 'bot:
http://youtu.be/cyMTlgvDjZM
It works pretty well propelled by both pneumatics and surgical tubing, but we need to control the distance. And to auto-load balls.
Unread 10-01-2012, 13:06
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Team 3489's Catapult Prototype
Looks pretty good, how do you plan to auto load the balls?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Looks pretty good! As long as you can a) control distance and b) aim somehow (via turret or turning the robot), you should have a pretty solid thrower, good job with thinking outside the box and using a catapult.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 10-01-2012, 13:09
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
What kind of distance were you getting with your mock-up?
Unread 10-01-2012, 13:13
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
i like it a lot. even if u can't score consistently, if you were doing that from the far end of the field you'll be getting lots of shots off, and getting balls to your side of the field. The four basket arrangement might also help with the variability of the shots. you might not always hit the 3 pt shots but they could bounce off and land in one of the 2 pointers.
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If you can control the distance and alignment, that will be a really killer half court(+) shooter. What a great start and good luck on refining it!
I'm thinking a robot name of "MJ" for that bot.
Unread 10-01-2012, 13:21
AKA: Kevin Thorp
I think the trash can was about 25' away.
We haven't figured out auto-loading yet. A belt-type ball elevator is pretty simple. The tricky part is getting it from the top of the elevator to the "cup", one at a time.
Controlling distance is another challenge. We might preload the rubber tubing by winding it up around a spool with a revolution counter. And/or adjusting the air pressure. I wonder if we're allowed to use electronically-controlled pressure regulators?
This is getting complicated. A spinning wheel launcher is pretty simple.
Unread 10-01-2012, 13:27
Tom I's Avatar
AKA: Tom Indelicato
If you're throwing that reliably from 25 feet, maybe you could consider specializing in throwing from the other side of the court, say like in your protected alley. This would allow you access to balls automatically from your alliance inbound area, and maybe you'll just always throw from x- distance away. sure it would limit your range of throwing, but hey "The Jack of all Trades is the Master of None." Being amazingly consistent at one thing is better than being somewhat consistent at a lot of things.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 10-01-2012, 15:56
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Get it to throw full field. I think it would be easier to make something for the inbounder to feed into than to make a ground-to-arm ball collector. I'm not totally convinced that it can't be done, since I haven't actually tried to design it, though.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 16:07
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
Man you catapult is awesome.
Unread 10-01-2012, 17:39
LabVIEW Rocks!'s Avatar
LabVIEW Rocks! LabVIEW Rocks! is offline
FRC #1778
LabVIEW Rocks! is an unknown quantity at this point
Get simplier, have 2 rails coming down to the launcher with a ball release barrier that can let balls through on the rail.
Unread 10-01-2012, 18:49
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Glad we could help
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 10-01-2012, 19:15
AKA: Kevin Thorp
Thanks! But remember when you watch these types of videos the robot is usually perfectly still, at a fixed distance and angle to the goal, and no other robots are harassing it.
What would really be awesome is a video of a robot making goals at 3 different distances.
Unread 10-01-2012, 19:16
AKA: Kevin Thorp
Originally Posted by Blackphantom91 View Post
Glad we could help
You could help even more by sending us your CAD files!
Unread 10-01-2012, 20:33
That would be no fun so you wouldnt learn. also there is a "TitaniumRule" which the GDC created we think because of us in 2009 (R78) in the rules so the design is illegal.
