Go to Post Excuse me while I rant on your comment here a bit. - Andrew Remmers [more]
Unread 10-01-2012, 14:50
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: 2012 Windriver Install problem
Originally Posted by cjlane1138 View Post
Also, make sure you install all of the National Instruments Software or you will not see the FRC Examples.
This is inaccurate. The NI software that needs to be installed is the Tools / Utilities base software. This installs the drivers needed by the cRIO Imaging Tool.
Originally Posted by Ross3098 View Post
This would mean that the WPILib would also be missing before installing the NI Software correct? Im currently wondering why I had no projects/WPILib files.
You need to install the C++ Workbench update to get the examples and WPILib.
Note that the installer first posted for kick-off was missing the WPILib.a file. This was corrected Sunday morning and should now be available and working correctly.
-Joe
