Go to Post In my opinion, the hardest part of the competition is not that actual manufacture of the robot, but the design process. It is the enginners that go through the design process all the time that will have the edge in this competition, not the best machinist. - Wetzel [more]
Unread 10-01-2012, 14:54
Greg1073 Greg1073 is offline
FRC #1073
Greg1073 is an unknown quantity at this point
Problems Connecting Target in 3.3
When attempting to connect to the target server on my robot, i get 91% of the way there before an error appears:
Step finished with this error: CPU: PPC603 is not licensed
Target Context VxWorks_10.10.73.2@WIN-PQHBGGVU39B
Target Connect Strategy: Wind River VxWorks Target Connect Strategy
Connect Step: Connect DFW
Target Communication Protocol: TCP/IP
Target IP Address: 10.10.73.2
Target Port: 0x4321
I am trying to connect via ethernet cable into my robot's radio.
I can Deploy and Undeploy but cannot debug.
I'm using Wind River 3.3 with new WPILib uptdate.
I would really like to be able to debug with WindRiver, so all the advice i could get would be greatlly apreciated.
Unread 10-01-2012, 15:08
Re: Problems Connecting Target in 3.3
Does the error go away if you explicitly select MPC5200 as the target?
Unread 10-01-2012, 15:17
FRC #1073
Originally Posted by Joe Ross View Post
Does the error go away if you explicitly select 5200B as the target?
What is that number? and where do i input it?
Unread 10-01-2012, 21:22
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
My team is also having this issue, flashed with v43.
Unread 10-01-2012, 23:30
normpear2 normpear2 is offline
Team Programming/Electrical Co-Lead
FRC #2603 (Highland FIRST Robotics Team #2603)
normpear2 is an unknown quantity at this point
Send a message via AIM to normpear2 Send a message via MSN to normpear2 Send a message via Yahoo to normpear2
HTML:
http://webcache.googleusercontent.co...ient=firefox-a
PDF:
http://www.usfirst.org/sites/default...bench3%203.pdf
Try reinstalling WindRiver. Installed 3.0.1 (Disk 1) DO NOT OPEN when completed. Uncheck to open when Setup is closed.
If your on a 64 bit version of Windows 7 or XP (You can check by Right Clicking Computer and going to Properties, it will say weather Windows is 32 or 64 Bit)
Install 3.3 (Disk 2) ONLY on a 64 bit OS, Else do not install it. DO NOT open WindRiver until the correct software is installed (32 bit only 3.0.1, 64 bit both 3.0.1 and 3.3) If you open windriver before 3.3 is installed, you will get the error you are having.
Unread 11-01-2012, 02:58
moopydoopy moopydoopy is offline
moopydoopy is an unknown quantity at this point
You need to manually select 5200 as the target, NOT 5200B or automatic.
Unread 11-01-2012, 08:32
kccowan kccowan is offline
AKA: Ken Cowan
FRC #1073
kccowan is an unknown quantity at this point
Originally Posted by normpear2 View Post
HTML:
The docs are misleading for 32-bit Windows 7. In one place it seemed to say 3.3 was for all Win 7 and 64-bit XP.
On our 32-bit computer, we installed both 3.0.1 and 3.3 twice, being careful the 2nd time to not launch 3.0. Still had the problem. The 3rd time, we installed the first disk only (3.0.1), and now have a working computer.
The 64-bit computer still has the error. Is anyone able to run WindRiver 3.3 on 64-bit Windows 7?
KC
Software mentor, team 1073
Unread 11-01-2012, 14:55
AKA: Brad
#0190 ( Gompei and the Herd)
When setting up the target connection, be sure that you press the "Select..." button in the "backend settings panel", then select MPC5200. See the attached image for help.
Brad
Brad Miller
Robotics Resource Center
