Go to Post I'm not overdosed, I'm not even addicted. I just choose to never, ever, ever leave FIRST. - SL8 [more]
Unread 09-01-2012, 20:53
JellyMan JellyMan is offline
Mentor, Team 3414
AKA: Jeff
FRC #3414 (Falcon Robotics)
JellyMan has a spectacular aura aboutJellyMan has a spectacular aura about
Pitching Machine Wheel
We would like to explore the use of a single wheel pitching machine, but our team lacks the ability for most custom machining and fabrication. Can anyone suggest an off-the-shelf component to serve as the wheel?
We believe that the wheel should have substantial mass (for angular momentum) so that the speed of the wheel is not greatly diminished with every throw. So, we were thinking about using an aluminum hub wheel with flat polyurethane tread such as this one
http://www.greatlakescaster.com/colson_caster_corporation______10_x_3_polyurethane _on_aluminum_core_wheel-7.00010.976.php
This 10 inch wheel may be a bit large, but you get the idea.
Are we on the right track? Can you suggest an alternative?
We may also design the pitching machine to allow for a separate flywheel. This way, we could tune the momentum of the wheel.
Thanks!
Unread 09-01-2012, 20:55
Andrew Lawrence
Posts: n/a
Re: Pitching Machine Wheel
You don't need machining to make a prototype pitcher. Just connect a wheel to a drill, put the wheel between a compressed surface and the ball, fire put he drill, and push the ball through. Works every time.
Unread 09-01-2012, 20:58
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I was thinking about the possibility of adding dumbbells or other round steel weights to any kind of flywheel to add momentum. Might be worth a try...
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 09-01-2012, 21:00
krazyman1013's Avatar
krazyman1013 krazyman1013 is offline
FRC #0701 (RoboVikes)
krazyman1013 is an unknown quantity at this point
Use the Andy Mark performance wheels and attach weights as you see fit.
Unread 09-01-2012, 22:22
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
You might try a wheelbarrow wheel with a pneumatic tire would be a decent size and they are usually made of steel and are pretty heavy. It would pretty cheap and easy to come by and would give you the flywheel effect that you are looking for. They usually come with bearings in the hub so that might be a trick to figure out how to transmit the torque but nothing that a little creativity cannot overcome.
Unread 09-01-2012, 23:05
Henzado Henzado is offline
AKA: Porter Henze
FRC #1891 (Bull Bots)
Henzado is on a distinguished road
We did the very same Tonight, but with two wheels.
Unread 10-01-2012, 14:19
Nick LaPosta Nick LaPosta is offline
FRC #2495 (Hornets)
Nick LaPosta is an unknown quantity at this point
Send a message via AIM to Nick LaPosta
If you use one wheel to shoot it I would recommend putting it on the bottom of the launcher and squeezing the ball between that and the top of the barrel. That would create a backspin and make the ball more stable in the air and it would bounce less once it hits something.
TEAM 1647 - Mentor
TEAM 2495 - Mentor
Unread 10-01-2012, 14:30
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
been there, tried that. Not reccommended unless you want to spend a bunch of time waiting for the wheel to rev up.
When I was was on 1747 we used 3 Kit wheels from 08 (6") direct drive to a cim... it had plenty of power and was pretty accurate.With the current range of parts, it could be done using an FP in a planetary if you wanted to save the cims for the drivetrain.
the sytem used that as well.
Unread 10-01-2012, 15:23
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Here is a whole bunch of pitching machine videos from various companies that may be useful http://www.atomicrobotics.com/2012/0...-sizes-shapes/
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
