Go to Post We should have a rule in CD, no sad booboo faces that make you want to cry... - JaneYoung [more]
Unread 10-01-2012, 12:32
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
6WD: Driving the Center Wheel
When directly driving the center wheel of a 6 wheel drive train from the output shaft of a gearbox (with chains powering the outer two) where is it best to put the output shaft bearings?
Should there be one on either side of the gear (i.e. Toughbox style), one on either side of the wheel, or one on either side of the whole system? I know you're not supposed to put 3 bearings on a shaft, but would it be acceptable in this case?
Unread 10-01-2012, 13:23
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: 6WD: Driving the Center Wheel
It seems like all the cases you are bringing up would work just fine so long as you make sure not to have 3 bearings. It just comes down to how your chassis looks and where it is easiest and lightest to put the bearings.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 10-01-2012, 14:02
Robotics Engineer
Thanks, I was just worried about cantilevered wheels.
Unread 10-01-2012, 15:53
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
I haven't heard this before. Why cant you put 3 bearings on a shaft?
Unread 10-01-2012, 16:15
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
My initial thoughts is that your 3rd bearing can institute some preload onto the shaft if it not perfectly aligned with the other two bearing. i.e. 2 points a line will always intersect both point. 3 points you may not be able to draw a line to intersect all points.
There is nothing saying you cannot put 3 bearings on a shaft. We have done it before on our robots, but we have been pretty good about alignment and manufacturing these pieces.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
