Go to Post First'ers aren't 'normal' I guess. Whatever that word means now a days - dancingfool [more]
Unread 09-01-2012, 12:41
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Re: Mecanum vs The Barrier
Originally Posted by Charmander View Post
After reading all the posts so far, it seems that more people believe the mecanum wheels will be able to handle it. Would it be wise to put in the money (and weight) to buy the 10 inch heavy duty wheels over the 8 inch wheels?
Depends on the rest of your robot. If you need a low center of gravity, or to be close to the ground to pick up balls I would stick with 8"(My team has the 8" and I am unable convince our students not to use them). but if your have other factors that would need a ten get them.
Unread 09-01-2012, 12:45
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Originally Posted by ratdude747 View Post
maybe the uber-heavy 10" steel plated mecanums... those would hold up...
http://www.andymark.com/product-p/am-0298.htm
keep in mind they are HEAVY....
That's 52 pounds of wheels!!!!!
Unread 09-01-2012, 15:52
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Any concerns with the Mecanum wheels getting over the bridges? Is there going to be enough traction to climb the bridge enough to get on it and over it so you can cross or balance it?
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 09-01-2012, 15:58
T Wallas Pog's Avatar
T Wallas Pog T Wallas Pog is offline
FRC #2993 (Megabots)
Team Role: Driver
T Wallas Pog is an unknown quantity at this point
We have used the same mecanums without replacing any rollers for two years now. They have been over the Breakaway bumps and driven on asphalt during many fairs and celebrations and they are still working as good as ever.
Unread 10-01-2012, 16:33
fortinj1354 fortinj1354 is offline
Former Webmaster and Driver
FRC #2974 (Walton Robotics)
fortinj1354 is an unknown quantity at this point
Those go over the $400 individual part price limit.
Team 2974
2011- Smoky Mountain Regional Winners and GRITS offseason competition winner
2012- Peachtree Regional Engineering Inspiration Award and Palmetto Regional Entrepreneurship Award winners
Unread 10-01-2012, 16:43
Interesting how the wheels are mounted in the video.
Unread 10-01-2012, 17:29
I'm curious whether [R17] applies to a set of 4 mecanum wheels. They are available for $180 each, which would be legal under [R14]. However, a single mecanum wheel isn't very useful by itself, so [R17] might make them illegal.
Unread 10-01-2012, 18:02
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
buy them individually.
we had no problems with mechanum in 2010, just with everything else falling apart... the bumps were hard on it. depending on your strategy, there may be no need to cross the bump. however, the bridges will be fairly slippery.
i've been toying with the idea of having a pair of powered kop wheels that could be pushed down when needed, and lifted off the ground when not. I figure that they would overcome the mechanum's lack of traction, while still allowing strafing when not in use.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 11-01-2012, 02:57
Mandelbrot's Avatar
Mandelbrot Mandelbrot is offline
FRC #3007 (ROBOTITANS)
Mandelbrot is an unknown quantity at this point
Ha ha! Impressive that you noticed.
Humans are like slinkies. Practically useless, but still fun to push down stairs.
Unread 11-01-2012, 09:45
syquest syquest is offline
FRC #0623
syquest is an unknown quantity at this point
Smile Re: Mecanum vs The Barrier
Yeah, there should be no problem with buying a set of 4 since they are individual parts. It would be no different than buying something in bulk to save money. Even if you consider two wheels a set (Left and Right), you are still at $360.
I think the real concern is weight. With the SIMs you have invested a huge amount of your weight allowance on your drive train. Still tempting
Unread 11-01-2012, 14:33
bmlarson12 bmlarson12 is offline
FRC #1977 (LHR)
Team Role: Electrical
bmlarson12 is an unknown quantity at this point
Our robot in 2010 not only could get over the bump at high speeds with rough mecanums, but also seemed to have better traction than the high traction wheels. We were able to win against any other robot in a pushing contest unless they had the same wheels. I also noticed other teams with rough mecanum wheels outpushing most robots. Things can shake loose if you don't use locking nuts and lock-tight, but that was not a problem for us.
Unread 11-01-2012, 15:12
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
no they don't. you are buying 4 wheels.
all AM 4 wheel mecanum sets are over $400... and people have been using the sets legally for years under the same $400 rule...
Unread 11-01-2012, 15:16
Not.
Unread 11-01-2012, 15:18
ratdude747's Avatar
AKA: Larry Bolan
oops... memory fails me.
I wonder why I remember them costing more...
Unread 11-01-2012, 15:56
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
barrier for the win
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
