Re: Bridge material question
Watch out for shipping on a full 4 x 8" sheet of polycarb.
so im trying to build the seesaw (bridge) and i cant seem to find any plans/blueprints anywhere . can anyone help me out?
http://www.usfirst.org/roboticsprogr...Field-Drawings |
According to FTC Robotics, 2011 -2012 Edition either US Plastics or Mc Master Carr are good sources for this Plastic. We have used TAP Plastic. We have not purchased the plastic for the Bridge yet. We are still building Game pieces. We hope to finish tomorrow. FIRST Team #2643, Mentor
I would also try screen-door and awning installers to find polycarb sheets. they use them instead of glass for their doors.
#7
thank you
#8
hey so i pretty much finished making the bridge and have some concerns.
1. is it alright to NOT include a pinch guard? whats the worst thatll happen? 2. the real field will be made out of a kind of plastic which has a different friction than plywood. is the frictional difference that great that lets say if the bot goes fine on the plywood bridge. that it wont go as smoothly on the real field or vice versa? |
#9
There is a significant difference between the slickness of a plywood bridge and one with polycarbonate on it. If you can't afford polycarbonate, consider something e styrene or acrylic which might bee a little less expensive but would be durable enough for practice. Dr. Bob Chairman's Award is not about building the robot. Every team builds a robot. |
#10
so now that the bridge is completely done i realized some weird things, like that when its perfectly level the weight force it takes to push one side down is waaaay less then the other side so i just screwed some blocks of wood to the harder to push down side bottom to balance out the weight and it worked to fix that problem but its now completely not level when there's nothing on it so im scared that it wont be accurate when it comes to testing did anyone have a similar problem? or know if it will effect the testing?
#13
