Go to Post I feel like I need to rinse out my brain with drain cleaner - dlavery [more]
Unread 10-01-2012, 17:06
fortinj1354 fortinj1354 is offline
Former Webmaster and Driver
FRC #2974 (Walton Robotics)
fortinj1354 is an unknown quantity at this point
Question "Pitching Machine" motors
Has anyone had any good results shooting the balls a good distance accurately using any of the allowed motors other than the CIM motors? Do any of the other motors provide the required power to shoot at least half way across the field, or are we stuck having to use the CIM motors?
Team 2974
2011- Smoky Mountain Regional Winners and GRITS offseason competition winner
2012- Peachtree Regional Engineering Inspiration Award and Palmetto Regional Entrepreneurship Award winners
Unread 10-01-2012, 17:30
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: "Pitching Machine" motors
My team was prototyping this using treaded wheels with a CIM attached to each. We maybe were getting two feet out of them. To be fair the set-up was far from optimal and we've still got to try fiddling with the gear ratios, but initial results aren't that impressive.
Edit: No we haven't tried anything other than CIMs, but even the CIMS were unimpressive
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 10-01-2012, 18:16
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Do you need help with the math to find out how much energy it takes to get a basketball X feet?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 10-01-2012, 18:39
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Some examples of that would be nice ^^
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-01-2012, 18:41
Optimist Alumnus
AKA: Nathan
That would be very helpful.
Unread 10-01-2012, 18:49
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Since Work = 1/2 * mv^2 (final velocity) - 1/2 * mv^2 (initial velocity) and Work = Force * Distance, you can find the force can be found if you know the other variables. Use this spreadsheet for specifics including angles and the velocities you need.
So say you're shooting from 6 meters (about midfield) at a 45 degree angle at the top hoop.
f * d = (mVf^2 - mVi^2) / 2
f * 6m = (0.32kg * (8.98 m/sec)^2 - 0.32 kg * (0 m/sec)^2) / 2
f = (0.32kg * (8.98 m/sec)^2 - 0.32 kg * (0 m/sec)^2) / 12 m
/* Plug into Google */
f = 2.15 Newtons
Now, that's the net force exerted on the ball at the launch velocity. Add sin(angle) * force of gravity and you'll need to shoot the ball with about 9.1 Newtons of force (2.05 pounds). Again, use the linked spreadsheet to determine your angle and velocity.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2012, 18:55
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
If you took a momentum/impulse approach, do you think you would get the same answer, or would that add other factors in that this solution ignores?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 18:59
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
As a side note: Back in the day ('07 to be precise), when we were trying to throw Poof balls, we were getting an amazing lack of distance, sometimes maybe reaching 6'. This would have been pitiful in competition.
On a whim we decreased the space between the spinning wheels, thus "squeezing" the balls more. Suddenly, we were exceeding 30' on a regular basis, without any other changes to the thrower.
Photo of work in progress. Can't find one "proving" the distance, but the turned faces are an indication.
"It's NOT Just A Robot Thing!"
Unread 10-01-2012, 19:53
Djur's Avatar
WPILib
AKA: Sam Carlberg
Decreasing the space increases the linear momentum and decreases the angular momentum imparted to the ball. I think that squeezing this year's ball by ~3 inches total (i.e. 5" between wheels at their closest point) is a good starting point for experimentation to determine how to impart less spin to the ball (spin from each side cancels out, so that energy is wasted) and impart more linear speed (which does not cancel out).
Unread 10-01-2012, 20:30
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
You are going to want some backspin on the ball to make shots. There is a reason why NBA basketball players have good follow through, it puts backspin on the ball and aids the ball into the basket.
2012-2016 Wave Robotics Team 2826
Unread 10-01-2012, 20:34
Is the best method of achieving this by having two spinning wheels and spinning one faster than the other?
Djur's Avatar
WPILib
AKA: Sam Carlberg
That's easy to do - place the wheels below the equator of the ball and this gives it backspin. You'll need a free rotating wheel or something similar on top of the ball to prevent it from shooting out at weird angles, though.
That will work if you have the wheels vertically instead of horizontally with the top one spinning slower.
Unread 10-01-2012, 20:42
Optimist Alumnus
AKA: Nathan
Thanks for all the help, guys
Unread 10-01-2012, 20:45
You can get backspin with just 1 wheel...
Unread 10-01-2012, 20:50
Ninja_Bait's Avatar
AKA: Jake Potter
It's more efficient with two wheels instead of one wheel with a hood. The loss in momentum is divided over two wheels and the bottom wheel doesn't have to work against as much friction to launch the ball.
