Go to Post Friends don't let friends prototype alone. - SenorZ [more]
Unread 11-02-2009, 21:04
Parthenon Parthenon is offline
FRC #1325 (Inverse Paradox)
Parthenon is an unknown quantity at this point
"Allocating channel or module that is out of range"
I recently attempted to code pnuematics and I get this strange error in the console when i run C++ code in WindRiver
What i think is the problem is that my solenoid module is inserted in module 6. However, the default is 8. If it is in module 6, then the lights turn on. Otherwise, they do not turn on.
I have tried basically everything I can think of, yet it has not solved the problem.
I have also commented out the solenoid code in an effort to get Joystick input, but that does not work either.
Any help is appreciated.
Unread 11-02-2009, 22:23
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: "Allocating channel or module that is out of range"
The WPI Library expects that the solenoid module is in slot 8, and only slot 8. You might be able to make it work by changing the modulePopulation constant in SensorBase.cpp to have a 9472 module selected at the desired index.
I don't see any specific rules against doing this, but I also don't quite understand why you'd need to move it to slot 6.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 11-02-2009, 22:25
Not only does the WPILib code assume slot eight, but more importantly so does the FPGA.
Greg McKaskle
specifically how can i do that?
it just happened to be in slot 6 at the time and it turned on ....
Unread 11-02-2009, 22:30
MattD's Avatar
Greg McKaskle
I was actually just wondering that after looking into the source code further. Thanks for verifying it.
It looks like you'll have no choice but to use slot 8.
Unread 11-02-2009, 22:32
I still get this error when plugged into slot 8 and no lights turn on on the module
Unread 11-02-2009, 22:46
MattD's Avatar
If you still see that error on slot 8, it's probably because you may have forgot to make this change in the code when allocating a Solenoid object. If this isn't it, posting your code may help us help you.
Unfortunately, I don't think I can help very much with the lights not turning on.
Unread 11-02-2009, 22:49
make what change?
Unread 11-02-2009, 22:54
MattD's Avatar
I'm assuming that when you were trying to use slot 6, you had code that may have looked something like this:
Solenoid *s = new Solenoid(6, 1);
However, when you tried out module 8 again, you didn't change that. If you try to use a slot other than 8 in the software, it will generate that fatal error. Since by default module 8 is selected, the simplest thing to do is only provide one parameter: the channel number.
Solenoid *s = new Solenoid(1);
Unread 11-02-2009, 22:58
I tried that and I still got the error. I also unplugged the slot and commented out all solenoid code and still got the error =(
Unread 16-02-2009, 12:31
We've found a solution
We discovered the code wasn't compiling properly, so after we deleted the PPC603gnu folder, it began compiling again. This removed the error.
Secondly we plugged in the solenoid module into module 8. Initially I didn't think it needed power, but it actually did, so we hooked up a wago connector to it in 12v input on the power dist. board and everything was working
Unread 10-01-2012, 18:10
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
2012-version thread resurrection
We are getting this from our cRio when running the SimpleTemplate sample code:
>>>>>ERROR: Allocating module that is out of range or not found: Digital Module 1 ...in InitPWM() in C:/WindRiver/workspace/WPILib/PWM.cpp at line 33
We tried the RobotDrive(SpeedController&, SpeedController&, SpeedController&, SpeedController&) constructor with our own Jaguar classes and we got the error for each SpeedController that we constructed. We got it with just the basic RobotDrive(int,int) constructor (it chooses slot 1 as a default, and errors out).
Unread 10-01-2012, 18:37
Do you have a Digital Module in slot 2 of your cRIO?
Unread 10-01-2012, 22:43
...with just the basic RobotDrive(int,int) constructor (it chooses slot 1 as a default, and errors out).
Watch out for a difference in numbering systems this year. It's not the cRIO "slot" that's important to the code. The "module number" is going to be 1 for the first Analog module (in slot 1), the first Digital module (in slot 2), and the [optional] first Solenoid module (in slot 3). On a 4-slot cRIO-II, the [optional] module in slot 4 is number 2; on an 8-slot cRIO, the [optional] modules in slots 5-7 are number 2.
Unread 11-01-2012, 07:23
Bongle's Avatar
Excellent, we will try that at our next opportunity. Do you know where the documentation is for that change?
Edit: Found it. We had glossed over the "setting up the control system" section because it said veteran teams were probably good to go with an old robot.
"Quotes" that were said during build season Jherbie53 General Forum 4874 Today 20:57
"This" or "That" Game! Chief Pride Games/Trivia 72 19-07-2012 16:36
"Prototype This" on Discovery Channel Dick Linn General Forum 15 25-10-2008 23:24
Recent movies that make you say..."wow" Greg Perkins Chit-Chat 18 03-11-2006 10:23
