Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 10-01-2012, 15:28
ajnack ajnack is offline
AKA: Alex Nackerud
FRC #2879 (Orange Thunder)
ajnack is an unknown quantity at this point
Throw or Drop?
For this year's game, is your team more interested in a throwing mechanism or a dropping mechanism? In other words, do you plan to throw the ball into the hoop, or drop it and why?
I'm just wondering so I can see what other teams plan to do.
Unread 10-01-2012, 15:32
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Throw or Drop?
I see benefits in both, so our jury is still out on that one. Good luck
Unread 10-01-2012, 15:34
Djinn74's Avatar
Djinn74 Djinn74 is offline
C++ Ninja in training
AKA: Henry Braeske
FRC #3397 (Robolions)
Djinn74 is an unknown quantity at this point
Re: Throw or Drop?
Well, since its illegal to get directly over the baskets, dropping will be hard.
I bet it could still be pulled off, though.
"Its totally going to be a water game!!"
"Bet you $10 that it isn't.
"Yeah... not making that bet."
Unread 10-01-2012, 15:40
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Throw or Drop?
Dropping has the potential to be more accurate (less variables), but throwing reliably is WAY more versatile. If you can do it well and accurately, try for throwing.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 10-01-2012, 15:44
ahollenbach ahollenbach is offline
AKA: Andrew
FRC #0103 (Cybersonics)
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
Re: Throw or Drop?
Here's a little I've thought of (not at all exhaustive)
Dropping
Pros:
-Easier to implement for rookie teams
-Score three balls swiftly in a row
Cons:
-Can get pushed
-Can't drop into top row
Shooting
Pros:
-Score from far away
-Can score from "safe zone"
Cons:
-Shooting is less reliable
-Difficult for driver to aim (hard to get the right angle from far away)
-May have to realign for each ball
Note, that with a very strong programming team, the second (and possibly third) con of shooting could be avoidable.
I say, choose the tactic that best suits your team's abilities. If you are unsure about being able to shoot consistently, build a simple dropper, and prototype a shooter. If you finish a good shooter by the end, use that instead, but if you don't, you'll still be able to score.
Unread 10-01-2012, 18:43
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: Throw or Drop?
Curious how one can drop the ball, considering the length of the fender and the 14" extension limit on appendages.
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 10-01-2012, 18:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Throw or Drop?
Get as close as possible and up a little higher so you can drop it in by rolling it off a ramp?
(yuck)
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 20:46
Optimist Alumnus
AKA: Nathan
Re: Throw or Drop?
Seems highly difficult to pull off
Unread 10-01-2012, 21:54
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Re: Throw or Drop?
It's impossible for the high goal, but perfectly implementable with the middle goals.
Unread 10-01-2012, 23:14
peyton122995 peyton122995 is offline
FRC #3753
peyton122995 is an unknown quantity at this point
Re: Throw or Drop?
Well you are allowed to cross the plane with one appendage on the robot. You are allowed to cross 14" (inches) like you stated. And you can go a max of like 9 feet high if you were able to tilt whatever you were dropping the balls with, well at an angle and about 2 feet higher the velocity of the balls would take it the extra inches. You could even put a motor at the edge with a roller on each side to give it power at very close range.
Hope this helped. (My First Post)
Unread 11-01-2012, 00:03
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Throw or Drop?
84 inches is seven feet, not nine.
Also, Welcome to CD.
Unread 11-01-2012, 00:56
Jimmyk Jimmyk is offline
Time Lord
FRC #2521
Team Role: Electrical
Jimmyk is an unknown quantity at this point
Re: Throw or Drop?
We're going with shooting, after all as long as you can get a fairly constant exit velocity for the ball, and you know how far from the hoop your robot is it's pretty simple physics to calculate the angle needed to get the ball in the hoop.
Unread 11-01-2012, 01:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Throw or Drop?
Just saying, trying to drop the balls onto the baskets also might hinder other bots trying to shoot or do the same thing. That would be a great limiting factor in scoring.
Unread 11-01-2012, 06:40
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Throw or Drop?
If we were in a vaccuum!
Unread 11-01-2012, 07:41
Optimist Alumnus
AKA: Nathan
Re: Throw or Drop?
Good point, I forgot the baskets also protrude out so the three foot fender is a bit deceptive.
