Go to Post Most importantly, get some sleep. - Libby K [more]
Unread 10-01-2012, 18:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Throw or Drop?
Originally Posted by Mr. Pockets View Post
Curious how one can drop the ball, considering the length of the fender and the 14" extension limit on appendages.
Get as close as possible and up a little higher so you can drop it in by rolling it off a ramp?
(yuck)
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 20:46
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: Throw or Drop?
Seems highly difficult to pull off
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 10-01-2012, 21:54
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Re: Throw or Drop?
It's impossible for the high goal, but perfectly implementable with the middle goals.
Unread 11-01-2012, 07:41
Optimist Alumnus
AKA: Nathan
Re: Throw or Drop?
Good point, I forgot the baskets also protrude out so the three foot fender is a bit deceptive.
Unread 11-01-2012, 08:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Throw or Drop?
Originally Posted by dellagd View Post
If we were in a vaccuum!
Since we're not, all it takes is a consistent shooting mechanism and a little time spent to solve the problem empirically. One physical example is worth a thousand models, so go build something and see what happens!
Unread 11-01-2012, 09:30
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: Throw or Drop?
Our team has looked at both, and may end up with both. If the basket is 14 inches long then it ends up something like 3 -4 inches from the edge of the rim. I poured basketballs into a trash can from this distance with ease. We are trying to figure out a way to use a dumping basket as a hopper for a shooter so we can do both.
Unread 11-01-2012, 13:14
Optimist Alumnus
AKA: Nathan
Re: Throw or Drop?
Just checked the math:
Not possible to dunk/drop balls into the hoops (Though you can get really close)
Barriers:
Fender: 38.75"
Now all the things to take out of that:
Hoop: Inside Diameter 18"
Backboard: 0.5"
Connection from hoop to backboard: 6" from inside of hoop to backboard
Total: 24.5" + some tiny distance for the diameter of the hoop ring (the metal itself not the gap in the middle)
38.75 - 24.5 = 14.25
You are allowed to extend out 14"
14.25" - 14" = 0.25"
So even under ideal circumstances your extention falls just short of the hoop. Dunking is physically impossible without tipping your robot somehow, or violating the rules.
Unread 11-01-2012, 13:26
SimulationX's Avatar
SimulationX SimulationX is offline
FRC #2077 (Laser Robotics)
SimulationX is an unknown quantity at this point
Re: Throw or Drop?
can't you overcome a quarter inch with spin? what about the diameter of the ball?
anyways, my team is ging to try for a shooting mechanism, our ultimate goal being the ability to take half-court shots. we are still in the process of selecting the best way to do this though,...
Unread 11-01-2012, 13:46
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Throw or Drop?
Barriers:
Fender: 38.75"
Backboard: 0.5"
i believe you also forgot the width of your bumpers between your frame and the fender. so we add another 3.25 inches or so...
0.25'' + 3.25'' = 3.5''
Unread 11-01-2012, 17:23
JabariW JabariW is offline
AKA: Jabari White
FRC #1850 (Mechanicats)
JabariW is on a distinguished road
Re: Throw or Drop?
For the people who plan to drop the balls into the hoops..please keep in mind that there is a limit to how far something can extend from your robot. I believe that the limit is 14". Plus the fender is adding additional space away from the basket. With all that being said...my team (#1850) decided to throw the dropping idea out of the loop. I hope with the information that I just gave you is helpful. Good LucK!
