Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 10-01-2012, 18:40
come-at-me-bro's Avatar
come-at-me-bro come-at-me-bro is offline
Brony Overlord
FRC #3284
Team Role: Scout
come-at-me-bro is infamous around these partscome-at-me-bro is infamous around these parts
Re: 6 Wheel Tank Drive or Just Stait up Tank Tread?
The tank tread idea sounds interesting enough. When my team and I were brainstorming my robot idea involved a Tank tread.
I wish I still did robotics.
Unread 10-01-2012, 19:16
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Compromise. Do a half-track with turning front wheels.
Attending: MN Duluth Regional
Unread 10-01-2012, 19:51
jcarm's Avatar
jcarm jcarm is offline
AKA: Jeff Carminati
FRC #3044 (OxBE4)
jcarm is an unknown quantity at this point
ok thanks for the responses, i did look around and saw some different designs. But if i could get like a list of pros and cons on the two based on experience and reaserch, i think we may be going with a wider robot this year so any types of drive train that would be good for that would be helpful.
Thanks again
Unread 10-01-2012, 20:17
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Tank Treads
Pros:
-Constant platform of support
-Can go halfway off bridge, assuming central or rear center of gravity
-Hard for opponents to push around
-Good traction
Cons:
-Very expensive
-Complex
-Narrow range of uses
-Torque issues
6wd
Pros:
-Good support platform
-Fast turning
Cons:
-Typically on 4 out of 6 wheels
-Complicated
There are just my team's observations of other teams in the regionals (Boston) over the past few years. We've always stuck with 4wd Mecanum, so no first-hand experience.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2012, 20:29
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Djur View Post
Cons:
-Complicated
6WDs are on 4 out of 6 wheels, but the drop is so negligible that it never seems to matter with sticky traction wheels.
If 6WD is mechanically complicated, you've got a problem.
Unread 10-01-2012, 20:39
Djur's Avatar
WPILib
AKA: Sam Carlberg
It's not so much intrinsically complicated as it is more complicated than a typical 4wd setup and might have more potential points of failure (it depends on how power is transmitted from the gearboxes to each wheel).
Unread 10-01-2012, 20:40
mayde's Avatar
mayde mayde is offline
Team Captain / Pirate Queen
AKA: Mayde Smith
FRC #2865 (Roboteknix)
mayde is on a distinguished road
Send a message via MSN to mayde
[font="Book Antiqua"]This is almost purely opinion, but I hate the idea of tank treads: last year my team had a painful experience trying to use tank treads for our drive train- it was horribly slow on the carpet and we didn't do enough research before deciding on the treads. It drained our batteries like mad and affected our gameplay. This year we'll most likely be using a 6 wheel tank drive with an offset center wheel. It all depends on which design we decide on in the end. I did notice, however, that the KOP wheels this year are a lot sturdier than past years with more grip. So they may wind up being sufficient for something like scaling the mid-field barrier between the bridges.
Surprise.
Roboteknix 2865;
2010 Spirit- Portland Autodesk Regional
2011 Safety Captain - Seattle Regional
2012 Team Captain- Cheney (Spokane) Regional
Unread 12-01-2012, 20:03
SaintPikachu7's Avatar
SaintPikachu7 SaintPikachu7 is offline
FRC #4064 (inZombiacs)
SaintPikachu7 is an unknown quantity at this point
Question Re: 6 Wheel Tank Drive or Just Stait up Tank Tread?
Hey, so i'm on a rookie team working on the drive train with a 6-wheel tank drive (drop center) for our robot. drive train team isn't exactly sure of an efficient way to distribute the motors power to all 6 of our wheels. any ideas? we were thinking of perhaps keeping both the CIMple boxes in the back and extending the chain to run down the entire chassis, or we were planning to buy additional sprockets to reach down the wheels at the opposite ends of the motors. Any suggestions?
Unread 12-01-2012, 20:06
Get an extra sprocket on the middle wheel and a sprocket on the front wheel that lines up with it. Run chain. Done.
Unread 12-01-2012, 20:45
TechLizzy16's Avatar
TechLizzy16 TechLizzy16 is offline
FRC #3509 (Team Fallout)
Team Role: Marketing
TechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of light
My team thought about the tank drive idea but I know for sure we're going to use the 8"in mecanum wheels. ( I know I probably spelled that wrong.) I think the tank idea is great because I think it would help to get over the bridge or railing.
Tech Lizzy
Anna Kerr
2012-2013 Season
Team 3452
Berrien Springs Greengineerz
2011-2012 Season
Team 3509
Niles Team Fallout
Unread 12-01-2012, 21:21
missledojer217's Avatar
missledojer217 missledojer217 is offline
FRC #3230 (Prototype X)
missledojer217 is infamous around these partsmissledojer217 is infamous around these partsmissledojer217 is infamous around these parts
Our team has used tank treads since we started, and they work very well and have won us a lot of games. when force is needed. and it gets over the bar in the middle easy as pie.
Do not mess with me...
For you are crunchy and... taste good with... Uh... Ketchup
"Drink Mountain Dew, Eat Pizza, Make Robot, This is Life."
Unread 15-01-2012, 10:30
jcarm's Avatar
AKA: Jeff Carminati
FRC #3044 (OxBE4)
Ok thanks for all of the replies I think I have enough info to make my case, but feel free to keep discussions open.
