Go to Post "In the next 5 years, the GDC will intermingle this 2012 game with the mechanics of 2009's game and it shall be called Space Jam." - Tetraman [more]
Unread 10-01-2012, 19:30
burgisr burgisr is offline
burgisr is an unknown quantity at this point
Drive Station will not boot
When I try to start the classmate drive station it gives a message:
PXE-E61: Media test failure, check cable.
This occurs whether or not I mount the USB Key.
Should I be doing something different or is there a problem.
Thank you
Rich Burgis
New Team
Unread 10-01-2012, 19:33
Re: Drive Station will not boot
Your Classmate needs to be imaged before it will boot on it's own. Are you following the directions in the "Getting Started with the 2012 Control System" document on the Kit of Parts Technical Resources page?
Unread 10-01-2012, 19:53
On a brand new Classmate there is no operating system and you must boot from the E11 USB thumb drive that came in the kit.
  • Make sure the USB image stick is well and securely seated.
  • Press F11 repeatedly while the Classmate is starting up, don't wait for the logo screen. It can go by really fast and you can't push F11 too many times.
  • If you do it right you'll get a choice allowing you to pick the USB stick to boot from.
Unread 10-01-2012, 19:57
I have done that. It says the media is defective.
Thank you
Rich
