Go to Post Yes, I have already determined that the device is capable of launching 2,160 Krispy Kreme donuts into the back seat of my Mustang with a vertical displacement of 65 feet, without cracking the sugary glaze on a single donut. - dlavery [more]
Unread 10-01-2012, 19:14
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Square vs Wide Turning abilities
Hi everyone,
With all the bridges this year the wide frame is quite popular however it does have the disadvantage of being easier to tip over.
We were thinking of using a square base [27x27inch] to allow us to fit 3 bots on the bridge but not have it tip as easily.
However how well would a square frame turn compared to the wide?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-01-2012, 19:17
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Square vs Wide Turning abilities
It should be able to turn faster but with less power compared to a wide bot.
But could you explain how it would be less prone to tipping? It would appear to me that given the same height you would be just as likely to tip forward/back as a wide bot, and now given that you've cut down on your width, it would be easier to tip side to side than a wide bot.
KK4KQO
http://voltair.us
Unread 10-01-2012, 19:27
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Originally Posted by Mk.32 View Post
Hi everyone,
Square bases have the same (or a even slightly smaller) wheel base than a wide robot. There really isn't much advantage to having a 27" square robot.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2012, 19:28
Mk.32's Avatar
AKA: Mark
We were thinking that the fact the wheels are closer together would make it less likely to tip, but are not sure. Could anyone clarify this?
Unread 10-01-2012, 19:37
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
These threads might help a little. They're physics quizzes from ether (both of which I "won", may I add). The first tells you the torque (applied to the wheel) required to start a square, 4wd, robot rotating. The second is the same problem, but for all rectangular robots:
http://www.chiefdelphi.com/forums/sh...ad.php?t=98947
http://www.chiefdelphi.com/forums/sh...ad.php?t=98971
The result for the second is that tau=muNr/sqrt(f^2+1) where f is trackwidth over wheelbase. You can see that for a square bot, f equals 1, which yields the solution to ether's Quiz 5. A narrow bot (f<1) requires more torque and a wide bot (f>1) requires less torque. You can apply the same principles to other tank drive setups, too.
As for tippiness, changing your trackwidth will give you no boons. All the tipping forces are in the plane formed by the vertical direction and forward direction. A two-dimensional robot will act the same as a three-dimensional robot that is infinitely wide in this case.
If you want to go wide, go all the way.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 10-01-2012, 19:53
hollings hollings is offline
FRC #3098
hollings is an unknown quantity at this point
This all depends on where the center of gravity is on your robot.
Unread 10-01-2012, 19:59
For an explicit treatment where the CoM (Center of Mass) is offset aft of the CoG (Center of Gravity), see this link:
http://www.chiefdelphi.com/forums/sh...ad.php?t=99089
Unread 10-01-2012, 20:00
Ninja_Bait's Avatar
AKA: Jake Potter
Shhh.... that's quiz 7.
The torque analysis doesn't change; a smaller trackwidth, ceteris paribus, requires more torque to turn.
Nor does the tipping analysis. A thin bot is as likely to tip when driving up the bump as a wide robot when they have the same center of gravity relative to their geometric center. It's more likely to tip side-to-side as well, as Cuog has said.
EDIT: ether beat me to the link, but here's the analysis anyway.
Unread 10-01-2012, 21:32
DonRotolo's Avatar
Back to humble
FRC #0832
OK, so to summarize: A 27" square robot will tip at least as easily as a wide robot, and turn at least as poorly as a narrow bot. The worst of both worlds!
I say go for it.
