Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 09-01-2012, 20:22
jsmyth jsmyth is offline
FRC #3130
jsmyth is an unknown quantity at this point
Re: Bridges and Mecanum Wheels
the bridge is made out of polycarbonate, the rubber on the mecanum wheels will most likely cause more friction on this surface. sense these wheels rely on a lack of some friction for forward movment, will this increase in friction cause your robots from moving across the bridge or possibly slow you down.
Unread 09-01-2012, 20:25
This is a common misunderstanding. They do not rely on a lack of friction. See Post #12 earlier in this thread.
For more detailed explanation, there's lots of info here.
Unread 10-01-2012, 18:14
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
So can an experienced team with mecanum wheels on a bot test drive a bot over a mock up bridge with Polycarb, and on the HDPE key, and post the results?
Unread 10-01-2012, 20:26
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Team 2084 just tested out 120-lb robot from last year on a full-scale, functional bridge a mentor made for us. We could barely crabwalk (move laterally) up it, but the robot is really imbalanced, so that's not as large of an issue. The bridge was also surfaced with fiberboard, which at after a rough test we determined to have about 1/3 the CoF as HPDE like Lexan.
We'll also be getting a 48"x88" HDPE board soon, so we'll resurface the ramp and run the test again, but I can conclude that mecaums won't have too much trouble on the bridge.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2012, 22:31
maxwellt's Avatar
maxwellt maxwellt is offline
what time is it? 540!!!
AKA: Tim Maxwell
FRC #0540 (Talon 540)
maxwellt is an unknown quantity at this point
my team tested if mechcanum wheels could drive on the ramps which is made from white board material and all the wheels did was slide off of the white board so which means Mechcanum wheels will have no traction what so ever on the ramps, so they are not the way to go for the ramps
winning does not= trophies
winning = learning
FRC team 540's 2011 moto
Unread 10-01-2012, 23:43
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
could you two or other teams possible post a video so we can see. we do not have the resources to build a ramp quickly and need to see what it looks like.
cole?
Unread 11-01-2012, 00:15
Djur's Avatar
WPILib
AKA: Sam Carlberg
Delivered.
The material is a fiberboard with ~3x less friction than HDPE. To be more accurate, we're getting a piece of Lexan to replace the fiberboard and test mecanums that way.
Unread 11-01-2012, 00:45
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
We tested our old mecanum drive on the bridge after covering it with 2009's Regolith material (which, based on cursory testing, is slightly slipperier than the Lexan that will actually be on top of the bridge). The mecanum wheels move across it perfectly well, even from a standing start, although balancing with two mecanum robots was a little tricky and took about fifteen scary seconds.
I'm not terribly worried about the HDPE; people condemned mecanums over the bump in the field last year and that didn't mean anything. We'll try running some tests, but I'm fully confident that suspensions are not necessary to handle HDPE.
Unread 11-01-2012, 02:49
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
Our main mentor prototyped a mecanum base over the summer, so we were seriously thinking about using them this year. Due to all the concern, we obviously needed test them on the bridge with the polycarbonate.
Here is a video of three runs (and not a real driver controlling robot--just some old guy). You now have some evidence to ponder!
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 11-01-2012, 08:43
AKA: Pierce Jensen
From what I can tell from your video (Thanks by the way!), you seemed to have enough traction on the polycarb to climb, but what about being pushed? If you were to have a pushing contest on the bridge, would you slide? I am worried about the traction if when balancing, and we get pushed a little too far, and fall off the other side...
As a sidenote, your motors were direct drive nanoboxes? And those were backdriving as you slide down the ramp?
