Go to Post Basically, it just doesn't matter. - Mark Pettit [more]
Unread 10-01-2012, 20:36
usacat6 usacat6 is offline
AKA: Will
FRC #2228 (Cougar Tech)
usacat6 is an unknown quantity at this point
Missing Java Default Code Project
Issue finding the BuiltInDefaultCode Project to test crio firmware and other control components. Follwing the Getting Started guide procedure on page 23 and 24. Have checked the crio firmware version. No issue. Have checked the updates.xml from WPI, the version is correct. Loaded plugin via the url link to WPI. Using netbeans 7.1. Thoughts?
