Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Unread 10-01-2012, 20:53
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Wolfgang is an unknown quantity at this point
LabVIEW Kinect Light and Depth
Does anybody out there know if we can use LabVIEW to communicate with the Kinect and detect reflective tape and depth? If so try to describe or explain here.
Unread 10-01-2012, 21:00
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: LabVIEW Kinect Light and Depth
Yes. You can. I would, however, recommend not putting the kinect on your robot - it'll be much more work than necessary. The axis camera we've used in the past will work just fine. I explain a little bit about image processing and depth finding in this thread. Check it out.
Unread 10-01-2012, 21:04
It isn't clear, but I assume that you mean putting the Kinect on the robot. Personally, I think that is a big project, likely involving yet another platform to program and connect.
The white paper on the NI site and on CD will give some other ideas for locating the target.
If you are serious about using the Kinect, I'd suggest that you break it down very carefully and identify how it will work and why it is worth the effort.
Greg McKaskle
