Go to Post Reffing a FIRST event is unlike being an ump or a ref at any other event. Where else is a game invented each year and over 1000 teams play this game within 3 months of its birth? - Andy Baker [more]
Unread 10-01-2012, 21:03
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Deploying application to cRIO
I have an application I want to deploy to the cRIO.
I have a crossover cable connected; do I right click my project and click the sunspot jar-deploy, the deploy, or what?
When I do the above two, I get some socket read error when netbeans tries to connect to the cRIO with FTP.
Unread 10-01-2012, 21:11
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: Deploying application to cRIO
Have you set your team number in Netbeans? Open netbeans preferences (varies platform to platform), click miscellaneous, and then click FRC Configuration, and change Team Number to your team number. Also, make sure that your IP address is on the same subnet as your cRIO.
Unread 10-01-2012, 21:21
ksafin's Avatar
AKA: Kirill Safin
Yes, I did.
When it's deploying, it says it connects via FTP to 10.39.92.6, which is the cRIO IP.
I have cRIO Image v43 loaded.
Was I deploying it the right way?
Unread 10-01-2012, 21:27
AKA: Oliver Graff
FRC #3780
It connectes to 10.39.92.6? The IP address of the cRIO should end with a .2 . Try disabling all network interfaces aside from the ethernet port. What is the IP address and subnet mask associated with that ethernet port?
Oliver
Unread 10-01-2012, 21:34
ksafin's Avatar
AKA: Kirill Safin
My bad, I meant .2, my laptop (classmate) is .6.
I did that as well, only my ethernet connection is enabled.
the IP is 10.39.92.6 and the subnet is 255.255.255.0
Also curious, aside from this,
how do we set up the D-Link wireless access point to control the drivetrain using the joystick wirelessly?
Thanks!
Unread 10-01-2012, 21:45
AKA: Oliver Graff
FRC #3780
Try manually connecting to the cRIO via FTP using a web browser, the url would be ftp://10.39.92.2 the user name is anonymous, and the password can be left blank.
Unread 11-01-2012, 00:27
ksafin's Avatar
AKA: Kirill Safin
We figured out what was going on, we needed to turn off windows firewall, it was blocking the FTP connection.
But now we have a knew problem.
We loaded code onto the cRIO, java code with an autonomous method and an operator controlled method. All we want to do is test it and try to run the motors using the autonomous code.
Now, we have Driver Station installed and it seems to find cRIO. But how to we run the deployed program in autonomous? When we clicked 'enable' for autonomous in driver station, nothing happened.
Our Jaguar's are also blinking yellow. Should this be like this (without running the program).
Thanks
Unread 11-01-2012, 03:12
AKA: Brad
#0190 ( Gompei and the Herd)
The java code is deployed when you press the green "play" button in netbeans. The code is automatically downloaded via FTP and the robot is rebooted with the code running. The first time you do this after reimaging the cRIO you have to manually reboot the robot after it deploys the java components. After that it reboots automatically on program downloads.
You'll know it worked because the Driver Station communications and program lights will both be green.
If that doesn't help, you'll have to post more details about your program.
Brad
Brad Miller
Robotics Resource Center
