Go to Post Not all creativity is visible or mechanical! - dtengineering [more]
Unread 10-01-2012, 21:55
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Problem installed FRC Plugin on Netbeans
My team is having problems installing the 2012 netbeans plugins for FRC.
There are no real errors during the installation but I do not see the FRC Icon in the tool bar nor do I see any FRC sample applications.
Any ideas?
Regards,
Dave Frederick, Manassas VA Team 1895
Unread 11-01-2012, 18:21
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
Re: Problem installed FRC Plugin on Netbeans
We are having the same problem.
We have installed the newest version of FRC java plugins for netBeans using the plugin update utility in netbeans.
After the installation we tried to open a new project but found no "FRC Java"
option. It look like the plugins are no longer installed.
If we make any discoveries, we will post our findings here.
Unread 11-01-2012, 18:34
pudgeball pudgeball is offline
AKA: Nick McGuire
FRC #2386 (BCHS Trojan Robotics)
pudgeball is an unknown quantity at this point
Can both of you confirm that the plugins are installed?
To do this, Tools->Plugins->Installed(x), then sort this list by 'Category' and try and find 6 plugins with the category 'FRC Java'. If you are missing these that would be your issue.
Unread 12-01-2012, 08:31
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Also, after installing/updating the FRC modules, NetBeans should have asked you to quit and restart NetBeans. Did it ask and did you restart?
Unread 12-01-2012, 09:21
AKA: Nick McGuire
This may help, this may not help but I'll say it anyhow. I had updated my dev computer to the 2012 updates, however I needed to work with a cRIO that I wasn't able to update at the time. So I downgraded to the 2011 update and it still didn't want to work. In the end I got it working with some prodding.
To get it to work, I uninstalled the plugins, then closed netbeans, then found where the wpilibj was installed (in my case, C:\Users\Nick\sunspotfrcsdk) and deleted that folder. I then installed the plugins again and it worked. Yes my case is different than yours but doing this may help you out.
Unread 13-01-2012, 20:46
FRC #1895
The problem continues I have tried a number of troubleshooting activities without any luck. Really frustrated.
Running XP with 512MB memory.
I can see the plugins listed on the DOWNLOADED tab but not the INSTALLED tab. Attempted local and network installs.
Did another (VMWARE) install with Netbeans 6.7.1 (and JDK) then FRC and still no joy. Thought maybe memory. So on the VM raised memory to 1G. STILL NOT LUCK.
I can see the modules listed (e.g. sqwuak) as Netbeans starts but no errors are presented....
I could use some directions on how to debug Netbean module loading.
Unread 13-01-2012, 21:08
AKA: Brad
#0190 ( Gompei and the Herd)
Have you tried a newer version of Netbeans? We've been testing with the most recent version of Java and Netbeans. Also we've been using Netbeans 6.9.1 with good results. That's what's on the automated test system.
Brad
Brad Miller
Robotics Resource Center
Unread 13-01-2012, 21:36
bdbayes bdbayes is offline
Captain
FRC #2927 (Pi Rho Techs)
bdbayes is a jewel in the roughbdbayes is a jewel in the roughbdbayes is a jewel in the rough
Have you tried installing the plugins manually? Download Manually
Unread 14-01-2012, 00:45
I was having the same problem.
It did ask me to restart. It closed, but did not automatically open. When I opened it manually, it would flash the plugin installing screen (not long enough to have actually installed the plugins) and then opened Netbeans. When Netbeans opened, the plugins were not installed.
I was using Netbeans 6.8. First I updated my JDK with no effect. Then I updated Netbeans to 6.9.1 with no effect. Then I deleted my sunspotsdk folder, and then I was able to successfully install the plugins.
Unread 14-01-2012, 08:18
FRC #1895
This looks like a system memory requirement.
Using VMWare and a number of tests, it looks like the new FRC plugins require a minimum of 768 Mb of system memory to be included on startup.
I guess I will start looking for some new laptops....
Unread 14-01-2012, 20:05
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
We were having similar problems with this year's NetBeans and FRC plugins on last year's laptops (although they had a clean OS install). By halving the number of laptops (to double the amount of RAM in each to 1 GB) we were finally able to get it to run.
Unread 16-01-2012, 18:59
zkxs's Avatar
zkxs zkxs is offline
Java Programmer / Electronics
AKA: Michael
FRC #2004 (Thunderducks)
zkxs is an unknown quantity at this point
I have also been having this problem. The first time was on a laptop running Windows XP. I'm not sure how much RAM it has. I finally got it working by completely uninstalling and reinstalling NetBeans. I am now trying to get the plugins working on my Linux box. I seriously doubt memory is the (only) problem here, as it has 12 GB of RAM.
Unread 16-01-2012, 19:20
Captain
I would hope ram is not the problem. :-)
Unread 17-01-2012, 08:28
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
I doubt RAM is the issue have had this issue on computers with over 4GB of RAM. Deleting the sunspot folder and installing the plugins manually worked for me.
Unread 17-01-2012, 08:30
Captain
In the past, I have been able to run with only 2GB of ram.
