Go to Post If I had a dollar for every time I thought we'd get a legitimate hint....Well, I might have a few dollars... - Andrew Blair [more]
Unread 10-01-2012, 22:29
Re: What are you doing different from last year?
Originally Posted by jhersh View Post
Also look in the LabVIEW for FRC 2012 examples. There is a new example to show how the Configuration File API can be used.
What is the example called?
I didn't see anything in the FRC section that seemed like it. Searching for Configuration found the Write Configuration Settings File and Read Configuration Settings File in Fundamentals\File Input and Output.
Unread 11-01-2012, 02:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I'm not sure where it is in the example finder, but in the file system it's under examples/frc/file/read and write preferences or something close to that.
Unread 11-01-2012, 10:06
I found it on the filesystem, but not in the example finder. I created a tracker.
Unread 11-01-2012, 13:52
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Originally Posted by plnyyanks View Post
To do this, all you have to do is flatten your data to a string and write that to the INI file, and then read it and unflatten it (just like you would with XML data). The only problem is that you can't read/edit the INI file in a text editor, but that problem is there whenever you use "flatten to string". Attached is some sample code to illustrate what I mean.
The openG INI toolkit does exactly this except it tries to keep the various sections human readable. Any kind of data can be passed to it.
Mike B
