Go to Post Aaaah - interpersonal dynamics - the root of most problems on most teams. - UCGL_Guy [more]
Unread 10-01-2012, 22:45
Wildcat Robotic Wildcat Robotic is offline
FRC #3039
Wildcat Robotic is an unknown quantity at this point
cRIO Imaging Tool trouble
Whenever I try to put the new image on the cRIO, it'll give me an error while it's formatting. It said that the possible error was that it timed out while rebooting or something. Any ideas? Thanks.
Unread 10-01-2012, 23:02
Re: cRIO Imaging Tool trouble
Some laptops don't handle the cRIO IP changes/reboot well.
It often helps to connect your laptop to the cRIO through a network switch rather than directly. The network switch remembers the connection to the cRIO longer before aging it out, lasting through a reboot, while some laptops see the cRIO disappear immediately and break off the connection right away.
Unread 10-01-2012, 23:05
FRC #3039
Thanks! About how much would a network switch probably be, and where could I find one? I'm not too savvy with networking stuff.
Unread 10-01-2012, 23:13
You have one in the kit.
Unread 10-01-2012, 23:16
FRC #3039
Ah. I feel silly. Thanks so much!
Unread 10-01-2012, 23:28
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Just wondering, since I like to know the details of what is actually going on, is the ARP table time to live on switches higher than on computers? Does windows just clear the ARP table when a cable is unplugged? Or am I misinterpreting the switch remembering the cRIO as an ARP thing when it really isn't?
Oliver
Unread 11-01-2012, 01:16
If you keep getting timeout errors, go through the usual checklist of network settings. DISABLE all firewalls. DISABLE all network interfaces other than the one actually connecting to the cRIO. Don't just disconnect them, or just turn off the WiFi. Make sure, of course, that your computer's IP address is compatible with your team number.
Unread 11-01-2012, 09:55
As you know, a network switch maintains an ARP and ages out connections gracefully for efficency's sake. Switches, routers, gateways, access points all have to be much more forgiving that a computer's NIC, because they must deal with more simultaneous connections, and momentary (or longer) communication glitches are much more common. Devices connect and disconnect all the time, and switches also keep track of which network hops are likely to lead to twice-removed machines.
An individual computer's NIC typically only talks directly to or through one other device, while a switch must maintain connections to dozens. The timeout on a switch or NIC depends on the manufacturer's attitude towards who they consider their market, so some timeout quickly, while others are more forgiving and take longer.
Part of the reason for the quick-to-drop attitude may be the evolving nature of mobile devices that must be on the lookout to change APs rapidly to maintain the strongest network connection. Switches don't roam as much as laptops do (except for those on our robots maybe).
Unread 21-01-2012, 15:51
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We are having the same problem and can't get it to work. Any other ideas?
Unread 22-01-2012, 01:28
Only the ones already posted. Have you turned off the Windows firewall? Have you gone into the network configuration and disabled extra network adapters?
Unread 22-01-2012, 01:46
kgzak's Avatar
AKA: Kris
Tried all that. Still didn't work. Switched to my computer and it worked. Must have been something about my dad's computer
Unread 30-01-2012, 15:13
Brobotics12 Brobotics12 is offline
FRC #2872
Brobotics12 is an unknown quantity at this point
For the past few weeks we have been trying to get our robot from last year to work. The driverstation is giving us a greenlight for everything including robotcode. We think it's a problem with the cRIO.
Unread 30-01-2012, 15:16
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
not a lot of information in your post to go on here !!
have you upgraded the cRio to version V43 ?
have you upgraded the imaging tool to the latest that came out a week ago ?
have you rearranged your modules to this years arrangements. If you haven't then you will get just what you described.
Ed Barker
Unread 06-02-2012, 16:52
FRC #2872
Okay I think I've managed to upgrade to the latest imaging tool, but I every time I try to re-image it with v43 an error pops up. When we tried it said "Unable to complete operation because of unexpected error:
Error 56 occurred at TCP Open Connection in NI_InternetTK_FTP_VIs.lvlib:FTP Open Data Connection.vi->NI_InternetTK_FTP_VIs.lvlib:FTP Data Send.vi->NI_InternetTK_FTP_VIs.lvlib:FTP [STOR].vi->ConfigUtility.lvlib:2012_FTPSubFolder.vi:1->ConfigUtility.lvlib:2012_FTPFolder.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlibialog.vi
Possible reason(s):
LabVIEW: The network operation exceeded the user-specified or system time limit."
Unread 06-02-2012, 21:46
Error 56 occurred at TCP Open Connection..."
If you search the Chief Delphi forums for that error, you will find many suggestions for how to proceed. The first one is to make sure you don't have a Windows firewall active. The second one is to disable all network interfaces except the one you're actually using to connect to the cRIO. The third one is to connect both the computer and the cRIO to the D-Link router instead of using a cable directly between them, though that usually gives a different error and should have been resolved in the most recent Imaging Tool.
