Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 11-01-2012, 00:25
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
CIM Motor Sacrifice
I was wondering how many people are thinking of sacrificing their CIM motors to use on their ball shooter or something else and just have 2 CIM's on the drivetrain.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 11-01-2012, 00:36
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Re: CIM Motor Sacrifice
Thinking about it? Definitely. Cims would be really helpful for a powerful shooting mechanism. We are of course wondering if we can run the robot over the barrier and the ramps fast enough with only two CIMS powering the wheels.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 11-01-2012, 00:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
You can add an FP motors as the 3rd/4th drive motors.
Though for a shooter, is the CIM really that much better then a FP motor?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-01-2012, 00:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Stall Torque: 2.42 N-m, or 343.4 oz-in
vs
Max torque (stall): 450 mNm (63.4 oz-in)
I believe quite a difference
Unread 11-01-2012, 00:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
vs
Apples and Oranges. It's all about power not just torque.
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
FP motors actually seem to be a bit better than CIMs.
In any case, using only 2 CIMs for drive will halve the power of your robot. Replacing 2 with FP motors will help, but you'll get weird, unequal forces that are really only good for a basic 4wd robot. Using 2 FP motors for a shooter and 4 CIMs for the drive keeps the drive consistent in terms of power and allows you to use different types of drive, especially omni/mecanum, which are practically impossible if you're using motors with different torque and speeds.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 11-01-2012, 00:46
Not to be rude, but there's some faulty logic and a heck of a false-statement if I've ever seen one.
Unread 11-01-2012, 00:52
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
Would you guys mind clarifying your choices? My team has been looking into motors to serve a pitching machine styled launch system and I was originally thinking that we would start with the motor with the highest rpm... and hadn't even considered using Cims here. What should we be looking for in relative motor torque vs rpm? Thanks!
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 11-01-2012, 00:54
Djur's Avatar
WPILib
AKA: Sam Carlberg
I'm coming from a team that has only ever used mecanum while I've been on it, so I'm probably exaggerating by a lot. But my omni/mecanum statement still stands.
Unread 11-01-2012, 01:21
Fair enough. I see your point now.
Unread 11-01-2012, 01:43
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Back to OP, this year we are placing a BB 775 with a CIMulator gearbox in places where a CIM would be normally used.
You could do this on your drivetrain or anywhere else really. If you are going to build a ball pitcher, I would use the 775s and keep the more powerful CIMs for drive.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 11-01-2012, 02:38
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
This is EXACTLY what I would do.
Unread 11-01-2012, 02:44
Mk.32's Avatar
AKA: Mark
If we go with the shooter, probably what we would do.
Use the FP/775 and leave the CIMS in drive.
Unread 11-01-2012, 03:04
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
In general I think you will see a lot of 775 based shooters. This years motor allowance gives a lot of variability of what you can and cannot do, you can go 775 cimulators for the drive or the shooter/ vice versa.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 11-01-2012, 07:17
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We have faaaaaaaaaaaaaar more motor power than we ever had available in the past this year. If you you can't figure out how to use the 22 available motor to make all you mechanisms and drive work then I would love to know what you're planning. We may not have the mini-bike motors we had during 2006 but we have far more power available with the replacements.
Thank-you 294 & 67
www.bobcatrobotics.org
