Go to Post "Take a man to a FIRST contest and he's entertained for three days. Teach a man to build a FIRST robot, and he's out of your hair for six weeks a year..." - kmcclary [more]
Unread 11-01-2012, 00:36
Re: v8 engine allowed?
As is my reply....
Unread 11-01-2012, 00:40
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Guys,
Did you not read...
The only legal source of electrical energy for the Robot during the competition is one MK ES17-12 12VDC non-spillable lead acid battery, or one EnerSys NP 18-12 battery, as provided in the 2012 KOP. This is the only battery allowed on the Robot.
At the same time.. That can be the only source of electrical energy. The rest is just done by the v8.
I'm right 90% of the time, so why worry about the other 3%?
Unread 11-01-2012, 00:43
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Our team began prototyping last year with a matter-antimatter engine until we realized we had gone way over the $3500 allowed on a robot. I'm sure it would have won us the Engineering Inspiration award if we'd been allowed to use it though.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 11-01-2012, 00:48
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
EDIT: ^^ quote fail.
The V8 produces electricity to fire the spark plugs(alternator).
However, you could a V8 diesel (no spark, no alternator necessary).
problem solved
(now for weight... freshmen with holesaw)
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 11-01-2012, 00:55
Cecil's Avatar
AKA: Alex Hummel
I guess at the same time, you would have to switch the starter motor out with something from the Kit of Parts. Either that or stand on the field before the match starts with a hand crank
Unread 11-01-2012, 00:57
Build Lead
Depending on the gear ratio, you could probably get away with a CIM. Or you could rest one of the wheels on the ground, drive forward, and pop the clutch.
Unread 11-01-2012, 00:59
Cecil's Avatar
AKA: Alex Hummel
Announcer: "I need a few volunteers from the audience to push start this machine. Anyone willing? Anyone?"
Unread 11-01-2012, 01:04
Build Lead
Inspector: *with puzzled/ frightened face "sooo, you are telling me that you removed the muffler, and drilled holes in the block... for lightness? And you expect the audience to push start it every time that it's on the field?"
Me: "Yes"
Unread 11-01-2012, 01:07
lonnie lascelle's Avatar
lonnie lascelle lonnie lascelle is offline
Team Mentor
FRC #0930 (Mukwonago BEARs)
lonnie lascelle is on a distinguished road
So we were able to find one of these V8 pitching machines at the local junk yard. We did make use of the seat motor voucher. We removed the old V8 500hp high output engine and figured with a couple of modifications we are able to run this unit with the new BBgear box. The BBv8-6-550 1:4000 ratio takes (6) 550BB motors to one 2" shaft output. We ordered one right away, it should be here in two days. They still have a few instock but they are likely to be out of stock quickly when this secret hits the streets. Just wondering if anyone else was able to get another one at their local junk yard?
Our total weight is still 40lbs under the allowable 1200lbs. so we should be great!
Lonnie
Cecil's Avatar
AKA: Alex Hummel
"These wheels.. Need a bit more guarding on them… A lotta bit… -looks to weight limit on scale- We are gonna need a bigger scale.."
Unread 11-01-2012, 01:11
Cecil's Avatar
AKA: Alex Hummel
Originally Posted by lonnie lascelle View Post
We ordered one right away, it should be here in two days. … Our total weight is still 40lbs under the allowable 1200lbs. so we should be great!
Wow.. That's the fastest turnaround time i have seen from BaneBots in years
And maybe.. Just maybe we can somehow add that extra 0 to R03 to make it official…
Unread 11-01-2012, 12:14
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
Question Re: v8 engine allowed?
derp no combustable are allowed in the robot
Unread 11-01-2012, 12:25
Build Lead
On it's own (aka vacume) diesel is not combustible
Unread 11-01-2012, 12:43
Michael Hill's Avatar
Looks totally legit to me.
Unread 15-01-2012, 12:22
c.fox's Avatar
c.fox c.fox is offline
Mr. Fox
AKA: Chris
FRC #2537 (RAID)
c.fox is an unknown quantity at this point
Re: V8 Engine Allowed?
Been there... done that. Broke the backboard.
We are now redeeming the BaneBot coupon for a 12v motor.
