Go to Post [when asked where to learn about robot parts] ...some forum called Chief Delphi. I hear the people there are pretty knowledgeable about this robotics thing. - EricH [more]
Unread 10-01-2012, 21:05
RahatAhmed RahatAhmed is offline
FRC #4300 (The Lion Kings)
RahatAhmed is an unknown quantity at this point
Program deployed, no response from robot
Hi, I'm a rookie this year, and I'm having trouble with the confusing documentation that we get. So far we've got the basic build done and the radio hooked up to the cRIO. We've had some networking problems as far as wireless goes, so we just use a long ethernet connection(we'll deal with one problem at a time).
I have been able to deploy the default RobotMain.vi program as-is to the robot. We're programming on the classmate so in order to get to the Driver Station we have to disconnect from the cRIO and switch user to Driver. After a lot of troubleshooting we have been able to get the DS to recognize the cRIO and that it has robot code. It also recognizes one of our joysticks. However, enabling the program doesn't do anything (in any mode). In the error box it mentions something about a while loop taking too long(I can't remember exactly right now, i'll edit this tomorrow when I'm back at school). The jaguars also keep flashing yellow no matter what we do.
1. Does anyone know how to get the program working?
2. Should I image our cRIO? We had it imaged on the kickoff so I don't know if it's the latest or not.
3. Should I install a newer Driver Station?
4. Should I install drivers for the Logitech Attack 3 joystick?
5. Slightly unrelated: Is there a good place to learn how to program the cRIO using LabVIEW? Not just the language itself but to control the robot.
Unread 10-01-2012, 22:38
Cancel's Avatar
Cancel Cancel is offline
AKA: Levi Trammell
FRC #3931 (Cockadoodle Dominators)
Cancel is an unknown quantity at this point
Re: Program deployed, no response from robot
Check your ribbon cable going from your cRIO and your sidecar. This year some of the cables have been messed up. Follow this guide to fix it.
http://www.usfirst.org/sites/default...structions.pdf
Unread 10-01-2012, 23:05
You don't have to switch users. You can run the Driver Station as a Developer.
This means they're not getting a PWM signal (I assume you aren't using CAN). It could be a wiring problem in several places, and troubleshooting that will require looking in detail at a number of things.
First, is the big amber Robot Signal Light plugged into the Digital Sidecar? If not, you can still look at the little green LED next to the RSL connector. What is the light doing when the robot is disabled? What is it doing when you enable the robot?
Second, is the Digital Sidecar properly powered? Are the BATT, +5v, and +6v green LEDs all brightly lit?
Third, is the cable from the cRIO's digital module to the Digital Sidecar assembled correctly? Some of the ones supplied in the Kit of Parts have one of the connectors backwards. See here for details.
I've heard good things about the http://www.frcmastery.com/ videos.
Unread 11-01-2012, 09:24
Do I just follow the instructions on installing the Driver Station again on the Developer account?
First, is the big amber Robot Signal Light plugged into the Digital Sidecar? If not, you can still look at the little green LED next to the RSL connector. What is the light doing when the robot is disabled? What is it doing when you enable the robot?.
I am not sure which green LED this is, do you have a picture of it? Also we have not installed the Robot Signal Light yet.
They are brightly lit, all the time while the robot is powered.
Our cable seems to be fine(no twist).
We also get an error message on the Driver Station. Something about error -44061 "left and right motor" loop is taking too long.
I've heard good things about the http://www.frcmastery.com/ videos.[/quote]
Unread 11-01-2012, 09:31
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I would also suggest that you try to get your hands on another computer to program on, it will make your life 100x easier. Even an old laptop donated from someone that isn't using it anymore will work.
Unread 11-01-2012, 09:33
Would a desktop work? I'm guessing we would need a wireless NIC, though.
Unread 11-01-2012, 09:39
Flywheel Police
Yes a desktop would work, and if you have a wireless router you could just plug into that and not have to worry about wireless card.
Unread 11-01-2012, 09:40
How would a desktop connected to a wireless router be able to communicate to the radio on the robot?
Unread 11-01-2012, 09:45
Flywheel Police
Same way it would with a wireless router, you set the IP address of the computer the same way you do for wireless. The router is basically just giving it wireless access. I will try to find the instructions for past years to set up a router configuration.
Unread 11-01-2012, 09:56
I thought that wireless routers created their own private network, separate from the radio's? The only way I could imagine that it would work is if you configured a router(maybe one with custom firmware like DDWRT) to become a wireless bridge that connects to the radio and connects the desktop to it. Then again, I don't really have a formal education in networking so what do I know.
Unread 11-01-2012, 10:13
Flywheel Police
Here are some instructions on how to set up a router to go in between a computer and the radio.
http://www.usfirst.org/uploadedFiles...ed-Rev-0.7.pdf
Unread 11-01-2012, 10:58
Wouldn't it be cheaper to just use the radio in AP mode and buy a wireless adapter for a desktop? We don't have any routers to use.
Unread 11-01-2012, 11:02
Flywheel Police
Yeah, that would be fine. We had the router from previous years.
Unread 11-01-2012, 11:11
RufflesRidge RufflesRidge is online now
The installation shouldn't be account specific. You should be able to find the Driver Station in the Start menu on the Developer account or in C:\Program Files\FRC Driver Station
Unread 11-01-2012, 11:32
Oh thank you very much!now we just gotta get those drivers working
