Go to Post You know, sometimes it is really cool to be a geek! - dlavery [more]
Unread 11-01-2012, 11:25
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: relative throughput of new/old cRIOs
Originally Posted by 1075guy View Post
Not enough to matter, not unless you're doing seriously high end trigonometry, triangulation, vision, and a bunch of interrupting.
like continuously calculating trajectory? continuously tracking a target using vision algorithms? running 6-8 PID loops at 50Hz? get the point?
Until 2009, we ran on an 8-bit microcontroller that had 4kB of RAM and 128kB of program space, operating at 10MIPS, and we did vision with that.
it was the 16-bit PICC I think and the vision code was so slow as to be almost unusable - and the camera did some of the work back then
The cRIO runs at something on the order of 400MIPS, and has far more RAM/Program Space. If any of us start saturating its capabilities, I'll be amazed.
be amazed, have you seen all the other crap running on that processor? but I basically agree, it should be enough.
Unread 11-01-2012, 14:16
If you want to get in to the gritty details, you can start here .
The FRC cRIO-II has twice the memory: twice the RAM, twice the FLASH, and twice the on-die cache in the processor. However, raw execution speed in the cores are (roughly) identical: both run at 400MHz and can issue up to 3 instructions per clock.
The extra memory is good for vision, but won't really affect things like trajectory calculations and PID loops. Simply put, anything that the PIC could do is trivially small on the new system. Bumping the number of PID loops from 8 to 80 would have no impact on performance, but bumping the image size from 160x120 to 640x480 certainly will.
Unread 11-01-2012, 14:35
Racer26 Racer26 is offline
It was a PIC18F8722. The specs I quoted came straight from Microchip.
You are correct that the camera itself did a bunch of the work, but the imaging code wasn't particularly slow. It kept up with the camera framerate.
