Go to Post I'm looking forward to January when things will slow down some! - Foster [more]
Unread 09-01-2012, 00:39
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
Reflective Tape Purpose
I'm sorry, this is a REALLY stupid question but I'm going to ask it anyways as I want to understand. What's the purpose of the reflective tape on the backboards. Is the assumption that we can get a camera on the robot to track our distance and orientation to the backboard with the tape? That's my assumption but in practice, that's a very hard problem to solve and my tiny bit of experience with computer vision makes me cringe to try it. The limited processing power available combined with the low resolution of the cameras and "swamping" overhead lights make this seem very nasty.
In theory, you can determine your angle in relation to the backboard as well as your distance by knowing the size of the rectangles in advance and seeing how much they "deform" and shrink. Your distance is determined by how large they are and you angle by how much they have skewed. This seems feasible but my experience with computer vision is with using feducial markers and very short distances. Even a sheet-of-paper-sized marker only works for about 8 feet on my webcam and that's in pretty good lighting.
Is anyone planning on really trying to do computer vision for those targets? Is there some trick to making them show up better? I'd love anyone's thoughts on this. Thanks!
-Mike
Unread 09-01-2012, 00:45
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Reflective Tape Purpose
Remember that this is supposed to be retro-reflective tape, meaning that light will be reflected back to the source. This means that maybe shining some sort of light may allow you to better pick up the rectangles and distinguish the shapes from the rest of the image. In any case, good luck!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 09-01-2012, 00:47
HA! I had something in my post about adding a big IR flood to the robot and using an IR pass filter on the camera to fix the lighting problem. Sounds like I might have been headed the right direction. Thanks!
-Mike
Andrew Lawrence
Posts: n/a
Are we allowed flashlights on our robot? To point at the retro reflective tape, not the other drivers.
Unread 09-01-2012, 00:49
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I don't think that it is required to see it. The boxes have black outlines. That should be sufficient.
Unread 09-01-2012, 00:51
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
It was last year, In fact it was specifically suggested at kickoff. I would be inclined to say yes; I saw nothing in the manual specifically barring non-concentrated light sources.
Unread 09-01-2012, 01:11
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Well, you would have to modify them so that they don't have batteries onboard, but yes, they are legal.
We made an LED array last year to light up the retro reflectors. It worked well, but due to encoder issues never saw any use.
Unread 09-01-2012, 01:38
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
First, are you sure this is retroreflective tape? It's just called reflective tape in the KOP list.
Secondly, if you're considering IR, you'll have to replace the entire lens of the provided webcam. It has a film that filters all IR out.
I'm looking forward to playing with this. We had a horrid time with last years vision targets.
Unread 09-01-2012, 01:43
Yup, that's what I was thinking. Just need to see if the rules allow it. On many cameras it's as simple as removing a filter. I've done it to a pair of webcams in the past and it worked great.
And that's what scares me. My experience with getting robots to "see" things has been poor consistently. I'm really unsure if it's worth even the effort. Did any team get vision targets working well?
-Mike
Unread 09-01-2012, 06:59
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
If you use the example tracker you can easily modify it to your needs. I believe tracking will win or loose the game this year. You either auto track the entire time so you can make baskets 90% of the time or you dont track and maybe get 10% of the baskets. Its going to be a difficult feet for everyone but every year there is a win or loose situation and I believe thats this years.
Personally, we are doing complete auto tracking. Trajectory planning and all in the code. Going for a 80% scoring throw from anywhere on the field. But really this depends a LOT on the mechanical also. They have to get the thrower throwing consistently before I can do any math to predict where it will land.
Unread 09-01-2012, 07:40
There should be a white paper on the NI site, but I haven't been able to find where they put it. Fortunately, Brad also posted it to FirstForge in the Documents sections. It is called 2012 Vision White Paper.
First off, yes, it is retroreflective tape, micro-sphere based, and quite bright. That means that if you use a ring-light, your camera will receive a rather isolated source of light that you control. The FIRST field is a pretty harsh and chaotic arena for vision experiments, but the end of the field where the drivers stand is not harshly lit or the drivers would be staring into the lights. Clearly many frequencies work with retro-reflection, but I'm not sure about its response across the spectrum including IR. Additionally, while it is possible and pretty easy to replace the lens in the Axis 206, the M1011 is an integrated lens. As a bonus, it is rather hard to see IR, therefore, harder to troubleshoot, inspect, and debug. So, my suggestion would be to go with team colors in the form of an LED ring-light. Or go with small LED flashlights on either side of the camera.
The example code that ships with LV doesn't attempt to compute angle information, but does include distance calculations. The code includes a color mask and a brightness mask with an optional Open operation and everything else is done with binary particles. The paper also discusses edge approaches.
One final wrinkle to throw into the mix is that there are enough communication paths to be able to do some/all of the vision processing on the laptop and send information back to the robot.
Greg McKaskle
Unread 09-01-2012, 09:14
DjMaddius's Avatar
AKA: Matt Smith
Greg McKaskle
Thanks for the information. I can't seem to find the paper though.
http://www.chiefdelphi.com/media/papers/
Is this the correct location of the paper supposedly?
Unread 09-01-2012, 09:16
It can be found here:
http://firstforge.wpi.edu/sf/docman/...ib/docman.root
Unread 09-01-2012, 10:43
I hadn't thought to upload it there. It is on its way.
Greg McKaskle
Unread 11-01-2012, 12:50
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Greg: what is the lens thread on the Axis 206? I wanted to us an IR light last year, but was stumped by the filter in the lens. If you have any other specs that would help locate a reasonable substitute lens, those would be helpful too...
