Go to Post My wife just looked over my shoulder, shook her head, and said "Only engineers...." - Tom Line [more]
Unread 11-01-2012, 12:50
icetalker icetalker is offline
FRC #1742
icetalker is on a distinguished road
Thumbs down An idea how to get over barrier and tilt the bridge in one
My team having dismissed all my ideas I feel the need to get some verification whether they're actually worthless.
I only have the picture left, my CAD got corrupted(i got .dwg though)
You hit the bump, the inertia and additional acceleration push the top wheel down giving you more grip, etc to get over the barrier efficiently. These should be mounted upwards in the robot. The spring keeps the assembly in upwards position under normal circumstances.
To get over the bridges, you mount these without the bumper in front and you attach a system that allows you to manually tilt the assembly. You get close to the bridge, start tilting the assembly down, the bridge gets tilted and you drive on.
http://www.chiefdelphi.com/forums/at...d=13263042 31
The picture attached is just a simple mock up. A couple of things are messed up on it but I think you get the idea. Please let me know what you think.
Unread 11-01-2012, 13:40
TechLizzy16's Avatar
TechLizzy16 TechLizzy16 is offline
FRC #3509 (Team Fallout)
Team Role: Marketing
TechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of lightTechLizzy16 is a glorious beacon of light
Talking Re: An idea how to get over barrier and tilt the bridge in one
My team has been starting to design our robot and we are having issues as well with how to get over the bridges and the railing. I really like your idea and if it's okay with you I'd like to show your idea to my team members.
Have you had lots of experience in robotic engineering? I'm a newbie this year and am learning lots of new things.
Unread 11-01-2012, 13:43
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
You have to have bumpers on all sides to cover all corners....
2012-2016 Wave Robotics Team 2826
Unread 11-01-2012, 13:55
3640ginger 3640ginger is offline
FRC #3640
3640ginger is an unknown quantity at this point
yeah but the rules say just the corners not all the sides or am i looking at it wrong
Unread 11-01-2012, 13:57
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
How high is that front wheel going to be? Keep in mind, if the bridge is balanced, it's a foot off the ground. If it's tilted the other way, it's 2 feet off the ground!
Personally, I think many people are overestimating the difficulty of driving up the bridges. Being around for both Rack 'N roll and Breakaway, I've seen how easy it is to go up a ramp with a normal kitbot design. the biggest problem teams had in those years was bottoming out transitioning from the ramp to the horizontal elevated portion. That's not a problem this year!
All three of these robots had more or less normal drivetrains, and that ramp is probably steeper than the bridge this year! http://www.chiefdelphi.com/media/photos/27516
(that's my absolute favorite robotics picture of all time, btw!)
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Has to be at least 8 inches coverage from each corner . . on each side.
Yes but you have to have 8 inches on each corner so unless you have your wheels more than 8 inches from the outside of your frame on each side they will be covered by bumpers.
also when the bridge is balanced it is 1ft off the floor....
Unread 11-01-2012, 13:58
speedbuggy76 speedbuggy76 is offline
Manellis
AKA: Matt Ellis
FRC #0118 (The Robonauts)
speedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the rough
[R27]
Robots are required to use Bumpers to protect all exterior vertices of the Frame Perimeter. For adequate protection, at least 8 in. of Bumper must be placed on each side of each exterior vertex (see Figure 4‑1, Figure 4‑2, and Figure 4‑3).
So you need bumper on both sides of each corner
Mentor for Team 118 - The Robonauts
Former mentor of 2415 - The WiredCats
Former member of 1002 - The CircuitRunners
The rules state you have to cover all exterior vertices (aka corners), and that you have to have a minimum of 8" of bumper on each side of the vertex (corner). For most teams, 8" of bumper will completely cover the frame in front of the wheels.
Unread 11-01-2012, 13:59
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
8" on each side of the vertex per 4.1.6 Bumper Rules
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 11-01-2012, 14:00
Dan_Peake Dan_Peake is offline
FRC #0846 (Funky Monkeys / Gear Heads)
Dan_Peake is an unknown quantity at this point
I like the concept. If I have understood your vision, additional benefits, unrelated to bump crossing, are (i) it could also be configured to drop the bridge, (ii) be used as an extended contact point in the key for fowl point opportunism and (iii) if a motor (ballast) will be at the arm end, the mechanism could double as CG fine tune for balancing.
Dan
Unread 11-01-2012, 23:03
FRC #1742
I meant that the wheels be planted 8 in inward on both sides. Also the whole assembly would be longer than 1 foot perhaps. I haven't thought this out completely but i believe there's worth in the concept and it's worth developing by someone.
Unread 11-01-2012, 23:51
nitneylion452's Avatar
AKA: Joe Lee
If I remember the field tour videos (specifically episode 5) correctly the bridges will naturally return to their horizontal positions once there is no load on them, i.e., you won't have to worry about the bridge being any higher than 12" off the ground.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
