Go to Post If it were easy it wouldn't be worth triple the points, right? - SenorZ [more]
Unread 11-01-2012, 15:11
dekohn dekohn is offline
FRC #2817
dekohn is an unknown quantity at this point
Re: Motor/cRIO issue
Just for a test I moved the cards back to the OLD slots and the tool said they are OK now. So are we supposed to move these cards as per the Getting Started with the 2012 FRC Control System or NOT?
Originally Posted by dekohn View Post
I have an old cRIO and the FRC cRIO imaging tool keeps telling me that Slot and Slot 3 have Incompatible module in those slots even though I have the 9403 (Digital) in Slot 2 and the 9472 (Solenoid) in slot 3.
Any body else having this issue?
Dan Kohn
Technical Mentor for Memphis TN Area teams
Unread 11-01-2012, 15:13
What Image is on the cRIO, the tool should tell you that they belong in the old slots with an old image and in the new slots with the new (v43) image.
Unread 11-01-2012, 15:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
After you've updated the cRio (and your local tools) to the latest versions, you'll need to use the new slots. I have a feeling this is going to cause plenty of headaches for teams this year...
Unread 11-01-2012, 15:55
FRC #2817
I thought I had the latest version finally (been fighting with it....bricked the cRIO once and had to use last year's image tool to get it back). But double checked and NO I did not. Went back and did the 2012 image tool (and FRC_2012_v43.zip version) and it tells me the following:
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlibialog.vi
and when I close the error window the current image says "Unknown" and on a cRIO the status light blinks 2x indicating the new update did not take.
IP's are correct (this is a test robot/cRIO so we call it team 9999 and the IP address of the laptop is set at 10.99.99.6.
It is connected to the crio via a crossover cable directly connected to th crio and the wifi is off.
Any Ideas?
Dan Kohn
Unread 11-01-2012, 16:07
We were a Beta test team this past fall, and I'm pretty sure we saw this exact same issue with one of our cRio's (we have two - one from the first year they were included in the KoP, and another one we purchased in Dec 2010 so we'd have two last season). I can't be positive though, because I never looked closely at the error myself (one of the other mentors was working with the team on that).
I just got word back from our lead programming mentor that they finally got it to update successfully last night, though! Give this a try:
it finally updated successfully yesterday by unchecking the box on the authentication tab of the local area connection properties....no ieee authentication needed. having it checked with all of the other crio updates til now hadn't mattered and it didn't matter on the newer crio, just the oldest one. weird...
Unread 11-01-2012, 16:48
FRC #2817
Nop that wasn't it. But it did give me an idea. I have been using two laptops configured to be programming computers for the team (NOT the netbooks with the image from First). SO I grabbed the newly imaged netbook and guess what it worked!
My guess is that they did do something on the image (firewall, setting something) that lets the imaging tool work.
I am going to post it on their forum and see what they say.
Dan Kohn
Unread 11-01-2012, 16:51
Glad we could help spark an idea, and that you got your cRio working! Also, thanks for posting your solution here... I'm sure others are going to run into this problem, and it's great to have as many working solutions available for it as possible
Unread 11-01-2012, 17:05
FRC #2817
Just posted my theory to US First's forum
http://forums.usfirst.org/showthread...ed=1#post55790
Please let me (and other's) know if this works for you! I am interested in whether my theory holds true.
