Go to Post Id have to say, that is probably one of the most creative floats i have ever seen. then again, this is coming from a guy who hasn't seen many floats (disregarding the 32-bit ones). - Uberbots [more]
Unread 09-01-2012, 14:35
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Re: Poly Cord
What OD's did you guys use in the hollow and solid applications? I would think somewhere around 1/4" would be sufficient but then again I've never used them before.
Unread 09-01-2012, 14:36
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Poly Cord
Yeah 1/4" is what we used. It's the standard cheap yet effective stuff you can get from McMaster and other places
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 09-01-2012, 14:56
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Re: Poly Cord
Are there advantages/disadvantages to using solid as opposed to hollow tubing or vise versa?
Unread 09-01-2012, 15:02
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Poly Cord
Speaking as someone who was on a team which had little trouble with the solid core, I think the hollow core with connectors is the way to go.
1. Easier to work with at competition (don't need heat source)
2. Less time consuming (no waiting for cooling)
We used the solid core largely because we had some, tried and it worked. So we had no reason to try the hollow. I have no idea if one of the two variations is more robust than the other.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 11-01-2012, 08:51
JellyMan JellyMan is offline
Mentor, Team 3414
AKA: Jeff
FRC #3414 (Falcon Robotics)
JellyMan has a spectacular aura aboutJellyMan has a spectacular aura about
Re: Poly Cord
Thanks everyone for the info concerning the "polycord". I will be placing an order for the 1/4" hollow Urethane Round Belting and barbed connectors.
Two more questions:
1) These round belts in are normally used multiple loops. So, are you machining custom rollers with multiple grooves, or are you stacking off-the-shelf pulleys? Is there a material of choice for the rollers. I suppose aluminum, UHMW polyethylene, or even wood could be used.
2) If we use the barbed connectors, are these actually reliable? Has anyone tried melting the ends in addition to the connectors? Is this overkill?
Unread 11-01-2012, 08:54
Jared Russell's Avatar
Taking a year (mostly) off
Re: Poly Cord
Two more questions:
Our team has used hollow poly cord a couple of times.
1) You can do either. In the past we have generally stacked pulleys (either COTS from McMaster/SDP-SI or homemade), but a single roller with multiple grooves can be a more elegant solution. I have seen various plastics (UHMW and ABS mostly) turned into roller/pulleys on a lathe, and that works well for many.
2) We have only ever had problems with barbed connections when people got lazy and made poor quality cuts. As long as you make sharp, flush cuts and fully insert the barbs, you will have no issues.
Unread 11-01-2012, 09:56
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Poly Cord
we used the custom made ones. There are about 30 on our Lunacy robot (4 different lengths). we still use the robot for demos. none have broken.
I think we used either the 1/4 or 5/16th diameter.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 11-01-2012, 10:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Poly Cord
We're seriously considering using the round belting for a mechanism this year. One of the ideas I have in mind I either saw or heard about in the past, is to use something like 1.5" nominal ABS sewer pipe, and put short sections of 2" pipe, split lengthwise to make it just a little smaller, over the 1.5" pipe, leaving a short gap wherever a bolt goes. The outer pipe sections could be screwed to the inner one. The inner pipe would be supported at the ends by caps with bearing holes bored in the center, and a sprocket would be screwed to one end of the pipe.
Unread 11-01-2012, 11:28
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Poly Cord
Our lunacy bot used in house constructed PVC rollers (schedule 80) where the endcaps were drilled out to accept bearings and then it was glued together. To act as guides we sliced sections of PVC that had an inner diameter the same size as the outer diameter of the roller and glued them in place.
Last years roller claw used COTS aluminum rollers that someone found on McMaster.
Do be mindful of the span of your plastic rollers if you use them and how much tension they are under.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 11-01-2012, 12:05
Best Available Data
FRC #1778 (Chill Out!)
Re: Poly Cord
The coolest solution we ever came up with was to take a piece of thin wall aluminum tubing and mount four roller bearings on the robot and sit the tube on top of them. You can do it upside down too, the polycord pulls the tube against the bearings. We used the lexan "fingers" you can see to hole the belting in place, we never had a problem and in retrospect they could've been much smaller.
Unread 11-01-2012, 12:22
MrForbes's Avatar
AKA: Jim
Re: Poly Cord
That's a neat idea! You could use just about any kind of tubing with that design, as long as you can figure out how to drive it. Would another section of poly cord work as the drive system from the motor?
Unread 11-01-2012, 12:58
DoctorMagazine DoctorMagazine is offline
FRC #2144
DoctorMagazine is an unknown quantity at this point
Re: Poly Cord
Our team was considering using surgical tubing instead of polycord to pick up balls. Would this work?
Unread 11-01-2012, 13:22
Rookie Year: 1942
Re: Poly Cord
This is what we did here. PVC center, larger diameter PVC outer. Caps in the ends with bearings inserted.
http://www.chiefdelphi.com/media/photos/33017
Chris Fultz
Unread 11-01-2012, 14:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Poly Cord
We did essentially the same thing as 234 in 2009, but with a different size PVC. Here's the best picture I could find where you can really see what's happening.
http://www.chiefdelphi.com/media/photos/32480
Unread 11-01-2012, 15:17
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Re: Poly Cord
We essentially did the same as 234 and what Sean posted.
I would look at thin wall aluminum piping in your application for rigidity. The amount of tension on those belts tends to bend PVC over longer lengths. We put in a plug that sat in the middle of our PVC pipes to help keep the pipe itself from bending. It mitigated the problem, but if I were to do it again, I'd go aluminum.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
