Go to Post It does it automagically. - David Kelly [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 11-01-2012, 16:08
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: New to 2CAN and Jaguar
Originally Posted by mikets View Post
Wait, I found the scaling code in CANJaguar. It is in packFXP16_16. It means the full range is actually +/- 65536. So like I suspected, the outputValues in jag.Set() should always be in the range of +/- 1.0 and the CANJaguar module will scale it to +/- 65536 and send it to the jags. Then why do we need to multiply 150.0? I am confused.
The actual range depends on the mode. Look at the documentation for CANJaguar::Set.
 * Set the output set-point value.
 * The scale and the units depend on the mode the Jaguar is in.
 * In PercentVbus Mode, the outputValue is from -1.0 to 1.0 (same as PWM Jaguar).
 * In Voltage Mode, the outputValue is in Volts.
 * In Current Mode, the outputValue is in Amps.
 * In Speed Mode, the outputValue is in Rotations/Minute.
 * In Position Mode, the outputValue is in Rotations.
 * @param outputValue The set-point to sent to the motor controller.
 * @param syncGroup The update group to add this Set() to, pending UpdateSyncGroup().  If 0, update immediately.
Everything you see inside the CANJaguar class is to convert from the WPILib API formats (such as -1.0 to 1.0) into the binary format to send to the Jag. Since in speed mode, the units are RPM, I don't want to control my motor +/- 1 RPM... that's too slow. I set the RPM range in my example to +/- 150 RPM cause it made sense for the mechanism I was sensing with that encoder.
In the case of RobotDrive, it computes a motor output +/- 1.0 based on joystick inputs. If you are not using motors in Percent Vbus mode, then that's probably not a good range. The RobotDrive class allows you to specify a scale value by calling SetMaxOutput(); with a floating point number to multiply by the +/-1.0 values that it computes before they are passed into the Set(); call on each motor.
Hope that's clearer.
-Joe
