Go to Post each year the chairmans award is given to the team the judges think deserve it the most, for that year. How can it be any other way? - KenWittlief [more]
Go Back   Chief Delphi > Technical > CAD
Unread 11-01-2012, 16:21
sketner sketner is offline
sketner will become famous soon enoughsketner will become famous soon enough
Compatibility issues with the parts file for inventor 2012
[indent]As we began our design in Inventor we tried downloading the Parts files and the Commpetition field from the AUTODesk website. I have Inventor 2011 and tried to use the files and got a RSe stream error(compatabilty error is what it means. If somone could help me out here? I believe if someone could save the file as a 2011 version that would be wonderful.
[indent]Thanks for any assistance, Team 1599
Unread 11-01-2012, 16:44
KeeganP's Avatar
KeeganP KeeganP is offline
AKA: Keegan
FRC #2059 (The Hitchhikers)
KeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of light
Re: Compatibility issues with the parts file for inventor 2012
I have Inventor 2012 and can open every file from Autodesk website just fine. My problem is that our team uses Solidworks. I can't find the site with the KOP for Solidworks. Can anyone provide me with that link?
I feel like I am wasting my time by going into Inventor and converting each file to a STEP file and then opening it up in Solidworks...
Thanks!
Keegan
FIRST Team Pyrotech #3459
The Hitchhikers Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
Unread 12-01-2012, 13:16
It's been a few years since I messed with SW but I seem to remember it had an onboard system something like Inventor's content center, so that you could search for and import the files without leaving SolidWorks.
Thanks!
Keegan
Unread 12-01-2012, 18:33
deBossest deBossest is offline
FRC #3244
deBossest is an unknown quantity at this point
Hi, we are having the same problem as you are, have you found a solution to the problem?
Unread 13-01-2012, 12:46
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
If you can't use Inventor 2012, you could use Free Inventor Fusion to save the files in a neutral format for opening in 2011.
Students can download Inventor 2012 here http://www.autodesk.com/edcommunity
Anyone can download Inventor Fusion here http://labs.autodesk.com
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 13-01-2012, 13:04
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
The Competition Field is already converted to a STEP field, so you can open that in Autodesk Inventor 2011. Download it from the Education Community.
http://students.autodesk.com/?nd=kitofparts_view
Also in that area you can download the KOP from 2011. That would resolve most of your needs for CAD models.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
