Go to Post Change 'car' to 'robot', 'coffee' to 'mountain dew' and Tom Brady to will.I.am, and you have next year's kickoff intro. - Tetraman [more]
Unread 11-01-2012, 08:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Throw or Drop?
Originally Posted by dellagd View Post
If we were in a vaccuum!
Since we're not, all it takes is a consistent shooting mechanism and a little time spent to solve the problem empirically. One physical example is worth a thousand models, so go build something and see what happens!
Unread 11-01-2012, 09:30
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: Throw or Drop?
Our team has looked at both, and may end up with both. If the basket is 14 inches long then it ends up something like 3 -4 inches from the edge of the rim. I poured basketballs into a trash can from this distance with ease. We are trying to figure out a way to use a dumping basket as a hopper for a shooter so we can do both.
Unread 11-01-2012, 13:14
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
Re: Throw or Drop?
Just checked the math:
Not possible to dunk/drop balls into the hoops (Though you can get really close)
Barriers:
Fender: 38.75"
Now all the things to take out of that:
Hoop: Inside Diameter 18"
Backboard: 0.5"
Connection from hoop to backboard: 6" from inside of hoop to backboard
Total: 24.5" + some tiny distance for the diameter of the hoop ring (the metal itself not the gap in the middle)
38.75 - 24.5 = 14.25
You are allowed to extend out 14"
14.25" - 14" = 0.25"
So even under ideal circumstances your extention falls just short of the hoop. Dunking is physically impossible without tipping your robot somehow, or violating the rules.
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 11-01-2012, 13:26
SimulationX's Avatar
SimulationX SimulationX is offline
FRC #2077 (Laser Robotics)
SimulationX is an unknown quantity at this point
Re: Throw or Drop?
can't you overcome a quarter inch with spin? what about the diameter of the ball?
anyways, my team is ging to try for a shooting mechanism, our ultimate goal being the ability to take half-court shots. we are still in the process of selecting the best way to do this though,...
Unread 11-01-2012, 13:46
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Throw or Drop?
Barriers:
Fender: 38.75"
Backboard: 0.5"
i believe you also forgot the width of your bumpers between your frame and the fender. so we add another 3.25 inches or so...
0.25'' + 3.25'' = 3.5''
Unread 11-01-2012, 15:33
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
You might gain inspiration from 47's 2000 bot. It collects balls in a open ended box then lifted it up and spat it out
461 Westside Boiler Invasion
45 Technokats
Unread 11-01-2012, 16:35
Optimist Alumnus
AKA: Nathan
Re: Throw or Drop?
Well yes, but then you'd sorta be shooting it, not dropping/dunking it (unless we're talking about the 1 point basket. The two point baskets are both at 61", so there really wasn't a ton of vertical space to drop from anyway). Additionally, my calculations were incorrect (see next quoted post), and 3.5 inches is a bit harder to cover with spin alone (and at the point where it is covered you're not even close to dunking anymore).
Oops, you're right. Good call. Same conclusion regardless though.
Unread 11-01-2012, 16:47
come-at-me-bro's Avatar
come-at-me-bro come-at-me-bro is offline
Brony Overlord
FRC #3284
Team Role: Scout
come-at-me-bro is infamous around these partscome-at-me-bro is infamous around these parts
Re: Throw or Drop?
Our team decided that we should go for shooting.
I wish I still did robotics.
Unread 11-01-2012, 17:02
Re: Throw or Drop?
I think that any team that can quickly and efficiently score points will be very effective, and since time spent moving accross the field is time wasted, a shooting mechanism should be better.
plus, if one robot is REALLY good at shooting balls, the other two could just feed him the balls from the other side of the court
Unread 11-01-2012, 17:23
JabariW JabariW is offline
AKA: Jabari White
FRC #1850 (Mechanicats)
JabariW is on a distinguished road
Re: Throw or Drop?
For the people who plan to drop the balls into the hoops..please keep in mind that there is a limit to how far something can extend from your robot. I believe that the limit is 14". Plus the fender is adding additional space away from the basket. With all that being said...my team (#1850) decided to throw the dropping idea out of the loop. I hope with the information that I just gave you is helpful. Good LucK!
