Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Unread 11-01-2012, 13:52
gabriel9414 gabriel9414 is offline
gabriel9414 is an unknown quantity at this point
Cannot download files into the cRio
First of all i would like to state that we are a rookie team. We have a problem that we cannot seem to solve so I'd like to know if you could help us.
The problem is that every time we try to download any program into the cRio we get a message that says "Failed to connect to Real-time target".
I would like to know if any of you has had this trouble before.
Unread 11-01-2012, 14:01
Re: Cannot download files into the cRio
Several possible causes:
  • Make sure your laptop has a correct matching IP address on the NIC you are using, e.g., 10.xx.yy.6 It must be compatible to talk to the cRIO.
  • Has the cRIO been imaged (that's when it gets it's proper IP address)?
  • Can your cRIO Imaging Tool see the cRIO? What IP address does it report?
Unread 11-01-2012, 14:21
Also make sure you set the IP address in your LabVIEW project.
We tried to follow everything according to the maunals for help but some were outdated.
The ip we are using is 10.xx.yy.2 according to what we have found we replaced the xs and ys with our team numbers and we left the 2 as it was.
The cRio imaging tool displays the same ip connection as the one we set in the labview project.
I dont know if I made myself clear
Unread 11-01-2012, 16:46
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Did you disable any extra network adapters in the laptop? For example turn off wireless while you are trying to get it to connect with a cable. If you have successfully imaged the cRIO, try to ping it from a command prompt
ping 10.xx.yy.2
Brian K
Team 1225 Robotics Mentor
Unread 12-01-2012, 01:31
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
are you using a router our just directly connected to the cRIO? cross over or regular cable?
Have you tried using the driver station? what are the status lights in the diagnostic tab?
Mike B
Unread 12-01-2012, 23:44
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Read this, it is very helpful for getting things up and running...
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2012_Assets/Getting%20Started%20with%20the%202012%20FRC%20Cont rol%20System_2.pdf
