Go to Post Robot? What robot?! - LightWaves1636 [more]
Unread 11-01-2012, 17:42
warfaj's Avatar
warfaj warfaj is offline
FRC #0610
warfaj has a spectacular aura aboutwarfaj has a spectacular aura about
PID Subsystems Question
Is there any way of running multiple PID instances simultaneously from the same PID subsystem?
Let me clarify:
I want to run my drive train with a PID Subsystem but I need to set different set points for each side of the drive train. I also need to set different PID inputs. Is there any way for me to do this in one PID Subsystem? The PID constants are the same for both sides of the drive train.
PS. I know I can do this with two PID Subsystems but I think it would be better to have a single DriveTrain subsystem.
Thanks in advance.
Unread 11-01-2012, 17:48
Jared Russell's Avatar
Taking a year (mostly) off
Re: PID Subsystems Question
I would simply make a new subclass of Subsystem that includes the desired functionality. You can copy as much or as little of the PIDSubsystem code as you would like.
Unread 13-01-2012, 16:23
AKA: Brad
#0190 ( Gompei and the Herd)
The PIDSubsystem is just an encapsulation of a regular subsystem and a PIDController object. You can make your own Subsystem as was suggested that just has two PIDController objects in it. For common cases the PIDSubsystem works pretty well, but not always.
Brad
Brad Miller
Robotics Resource Center
Unread 15-01-2012, 23:40
youxinche95 youxinche95 is offline
AKA: Eugene Che
FRC #0649 (MSET)
youxinche95 is an unknown quantity at this point
I actually created a pid class with that passes the kP, kI, kD in the constructor and updates the target and current.
It works pretty well, and saves me lots of writing, because programmers are lazy
good luck!
