Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 11-01-2012, 17:54
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Re: Wind River Example Code
Well, three of the laptops on my team have the problem
And I installed the full version of Labview because
1. Excess of hard drive space, and I can always uninstall it later.
2. I have used Labview in previous years, and if worst comes to worst i thought I could try programming on that.
All 3 of ours are running windows 7 home premium or professional, 64 bit.
Unread 11-01-2012, 18:10
Sounds like you are missing the Workbench update:
http://firstforge.wpi.edu/sf/frs/do/...cts.wpilib/frs
Unread 11-01-2012, 18:11
Sounds like you need the FRC C++ Update. Go to firstforge.wpi.edu, find the WPILib project and click File Releases to find it.
Unread 11-01-2012, 18:24
SoyStuff SoyStuff is offline
FRC #1257
SoyStuff is a jewel in the roughSoyStuff is a jewel in the roughSoyStuff is a jewel in the rough
Smile Re: Wind River Example Code
It worked. You have saved my life.
Unread 11-01-2012, 23:08
Dusk Star's Avatar
AKA: Andrew
Thank you, RufflesRidge!
Unread 28-01-2012, 14:03
techno4229 techno4229 is offline
AKA: marcus
FRC #4170
techno4229 is an unknown quantity at this point
umm i did all that but i get a error when i try to load the downloadable example folder:
the capability vxworks6.x is invaild because of the underlying platform is not available. This leads to unexpected results in windriver workbench. please the installation
