Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
Unread 11-01-2012, 16:36
SoyStuff SoyStuff is offline
FRC #1257
SoyStuff is a jewel in the roughSoyStuff is a jewel in the roughSoyStuff is a jewel in the rough
Wind River Example Code
We have installed the second option on the flash drive already. We keep trying to install Wind River, and the installations are succeeding. However, we do not have access to the sample FRC code. It simply is not there. Also, we are running Windows 7 64-bit, and we know that we need to install disc 2 with version 3.3 without ever opening version 3.0. We've done that. Any ideas?
Unread 11-01-2012, 16:50
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Re: Wind River Example Code
I have basically the same problem (fully installed labview and windriver, but no FRC code in either), though I had installed windriver before the labview flash drive. I also did option 1, the full install, for labview.
If anyone has a source for the example code, I think both of us would be very grateful!
Unread 11-01-2012, 17:05
FRC #1257
Oh. We installed option 2. You don't need the full install to write C++. Then again, this doesn't seem to be working. Have you had any success finding help? Do you know if any other teams have this problem?
Unread 11-01-2012, 17:54
Dusk Star's Avatar
AKA: Andrew
Well, three of the laptops on my team have the problem
And I installed the full version of Labview because
1. Excess of hard drive space, and I can always uninstall it later.
2. I have used Labview in previous years, and if worst comes to worst i thought I could try programming on that.
All 3 of ours are running windows 7 home premium or professional, 64 bit.
Unread 11-01-2012, 18:10
Sounds like you are missing the Workbench update:
http://firstforge.wpi.edu/sf/frs/do/...cts.wpilib/frs
Unread 11-01-2012, 18:11
Sounds like you need the FRC C++ Update. Go to firstforge.wpi.edu, find the WPILib project and click File Releases to find it.
Unread 11-01-2012, 18:24
FRC #1257
Smile Re: Wind River Example Code
It worked. You have saved my life.
Unread 11-01-2012, 23:08
Dusk Star's Avatar
AKA: Andrew
Thank you, RufflesRidge!
Unread 28-01-2012, 14:03
techno4229 techno4229 is offline
AKA: marcus
FRC #4170
techno4229 is an unknown quantity at this point
umm i did all that but i get a error when i try to load the downloadable example folder:
the capability vxworks6.x is invaild because of the underlying platform is not available. This leads to unexpected results in windriver workbench. please the installation
