Go to Post I also hate it when I keep seeing this message: "You must spread some Reputation around before giving it to Andy Baker again." - dlavery [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 11-01-2012, 16:08
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: New to 2CAN and Jaguar
Originally Posted by mikets View Post
Wait, I found the scaling code in CANJaguar. It is in packFXP16_16. It means the full range is actually +/- 65536. So like I suspected, the outputValues in jag.Set() should always be in the range of +/- 1.0 and the CANJaguar module will scale it to +/- 65536 and send it to the jags. Then why do we need to multiply 150.0? I am confused.
The actual range depends on the mode. Look at the documentation for CANJaguar::Set.
 * Set the output set-point value.
 * The scale and the units depend on the mode the Jaguar is in.
 * In PercentVbus Mode, the outputValue is from -1.0 to 1.0 (same as PWM Jaguar).
 * In Voltage Mode, the outputValue is in Volts.
 * In Current Mode, the outputValue is in Amps.
 * In Speed Mode, the outputValue is in Rotations/Minute.
 * In Position Mode, the outputValue is in Rotations.
 * @param outputValue The set-point to sent to the motor controller.
 * @param syncGroup The update group to add this Set() to, pending UpdateSyncGroup().  If 0, update immediately.
Everything you see inside the CANJaguar class is to convert from the WPILib API formats (such as -1.0 to 1.0) into the binary format to send to the Jag. Since in speed mode, the units are RPM, I don't want to control my motor +/- 1 RPM... that's too slow. I set the RPM range in my example to +/- 150 RPM cause it made sense for the mechanism I was sensing with that encoder.
In the case of RobotDrive, it computes a motor output +/- 1.0 based on joystick inputs. If you are not using motors in Percent Vbus mode, then that's probably not a good range. The RobotDrive class allows you to specify a scale value by calling SetMaxOutput(); with a floating point number to multiply by the +/-1.0 values that it computes before they are passed into the Set(); call on each motor.
Hope that's clearer.
-Joe
Unread 11-01-2012, 16:18
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Ah, I missed the comments in the code. It must be too late in the night. Thanks. That's much clearer.
Unread 11-01-2012, 20:05
mikets's Avatar
Software Engineer
Actually, few more questions: is the kPercentVbus mode essentially kVoltage but just scale to the range of -1.0 and 1.0? Only kSpeed and kPosition modes use encoder/potentiometer? Are kVoltage and kCurrent modes also considered close-loop modes? To me, close-loop means feedback. Monitoring output voltage and current so it can maintain constant values seem close-loop to me too even though it is not using any "external sensors" such as encoder and potentiometer.
Thanks.
Unread 11-01-2012, 20:57
Thanks.
Voltage mode is different. Lets take two cases:
If your battery voltage is 12V and you specify 0.5 in PercentVbus mode, you get 6V and if you specify 6V in Voltage mode, you get 6V.
If your battery voltage is 9V and you specify 0.5 in PercentVbus mode, you get 4.5V and if you specify 6V in Voltage mode, you get 6V.
Position, Speed, and Current (the sensor is inside the Jag, but external to the controller) are closed loop modes that use a PID algorithm with feedback. The Voltage mode is not closed loop because the setting is simply scaled based on the bus voltage, not corrected based on the resulting output. This is because unlike the other modes, the voltage can be controlled directly.
-Joe
Unread 12-01-2012, 03:36
mikets's Avatar
Software Engineer
I got it to work now. Here is what I learned:
- My encoders are not working, it could be the cable. We will figure that out later.
- Apparently, if I do kSpeed mode, the motors jerk back and forth violently. Sort of vibrating loudly. That gave me the hint that the encoders are not working. I added a call to GetPosition and saw only zeros.
- So I changed the code to use kVoltage mode and scale the joystick values by multiplying with 12.0. This doesn't work either.
- Then I thought since the encoders are not working, I would disable all the encoder related initialization. To my surprise, that works. I would have thought the encoder is ignored when doing kVoltage mode, but apparently not.
- With the encoder initialization disabled, I changed the code to use kPercentVbus mode and removed the 12.0 multiplier. That also worked.
So the robot is totally tele-operating. Next step is to figure out what's wrong with the encoders.
Unread 12-01-2012, 03:52
Congrats! About the encoders affecting the Voltage mode, that should not be the case. Usually when something like that happens it means you got an error other than a timeout and the object has given up talking to the Jaguar until you either fix your code and rerun, or you call ClearError() on the object. Check for errors.
-Joe
Unread 17-01-2012, 05:57
mikets's Avatar
Software Engineer
Now that the Jags run successfully in kPercentVbus mode as well as kVoltage mode as long as all the Encoder related initializations are commented out, I am investigating what exactly caused this. I have isolated the culprit. It looks like all the encoder initializations are fine except for the SetPID calls. So basically, the following code doesn't work until I comment out the CULPRIT_CODE lines. Note that the Jags are initialized to kPercentVbus mode. Kp is 15.0, both Ki and Kd are zeros. What could have caused this?
class MyRobot: public SimpleRobot
private:
    CANJaguar m_jagLeft;
    CANJaguar m_jagRight;
    Joystick m_leftStick;
    Joystick m_rightStick;
public:
    MyRobot():
        m_jagLeft(CANID_LEFT_JAG, CANJaguar::kPercentVbus),
        m_jagRight(CANID_RIGHT_JAG, CANJaguar::kPercentVbus),
        m_leftStick(JOYSTICK_LEFT),
        m_rightStick(JOYSTICK_RIGHT)
        m_jagLeft.SetSpeedReference(CANJaguar::kSpeedRef_QuadEncoder);
        m_jagRight.SetSpeedReference(CANJaguar::kSpeedRef_QuadEncoder);
        m_jagLeft.SetPositionReference(CANJaguar::kPosRef_QuadEncoder);
        m_jagRight.SetPositionReference(CANJaguar::kPosRef_QuadEncoder);
#ifdef _CULPRT_CODE
        m_jagLeft.SetPID(DRIVE_KP, DRIVE_KI, DRIVE_KD);
        m_jagRight.SetPID(DRIVE_KP, DRIVE_KI, DRIVE_KD);
#endif
        m_jagLeft.ConfigEncoderCodesPerRev(DRIVE_ENCODER_CODES_PER_REV);
        m_jagRight.ConfigEncoderCodesPerRev(DRIVE_ENCODER_CODES_PER_REV);
        m_jagLeft.EnableControl();
        m_jagRight.EnableControl();
    void OperatorControl(void)
        while (IsOperatorControl())
            m_jagLeft.Set(-m_leftStick.GetY());
            m_jagRight.Set(-m_rightStick.GetY());
            Wait(0.005);
Unread 17-01-2012, 13:46
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
I don't know if this is your problem but kp=15 doesn't seem right. I was doing current control mode with the jags last night and i was using Kp=0.01 and Ki = 0.05. Regardless if you are in percent vbus mode I would think the PID gains should have no effect.
Unread 17-01-2012, 17:26
mikets's Avatar
Software Engineer
That's exactly my point. I was using PercentVbus mode, PID constants should be totally irrelevant and should be ignored. It is true that I could just comment out the SetPID calls and call it good since PercentVbus mode doesn't need them. But there are cases where I need to call ChangeControlMode and change to a close-loop mode. When that happens, I must call SetPID to set the constants. And later on, I may switch back to PercentVbus mode. If calling SetPID would make non close-loop mode not working, that's not very intuitive.
BTW, I set Kp to 15 because I tested the Jag with bdc-comm tool using Position mode and found that if the value is higher than 15 (e.g. 20), the wheel will oscillate before stopping at the target position. If it is less than 15 (e.g. 5), it takes a long time to get to the set target. I am not familiar with the internal PID algorithm of the Jags, but from my point of view, K should be different in different modes. For example, Kp is multiplied to the "error" to get the output voltage. Different modes have different units (Amp in current, rev in Position and rev/sec in Speed). So the error will be in different ranges and so the K multiplier could be quite different. Since I am new to Jags, I could be totally wrong but this is my understanding. Regardless, even if my K's are wrong, as you said, PercentVbus mode should ignore them anyway. So why would it not work if I called SetPID?
Unread 17-01-2012, 17:39
Can you confirm that you are not getting any errors from the set pid call?
Unread 17-01-2012, 18:41
mikets's Avatar
Software Engineer
SetPID is a void function. How do I check the "error"? GetFault()? If so, I did print out the value returned by GetFault in the loop. As far as I can tell, it's returning 0.
Unread 17-01-2012, 19:03
I will be working with the Jags tomorrow night. I can try to see if I see the same issue as you.
I am not familiar with the internal PID algorithm of the Jags...
The source code for the Jags is open. Here is the PID algorithm for fun:
// This function will execute another iteration of the PID algorithm.  In
// order to get reliable results from this, the sampled values passed in must
// be captured at fixed intervals (as close as possible).  Deviations from a
// fixed capture interval will result in errors in the control output.
long
PIDUpdate(tPIDState *psState, long lError)
    long long llOutput;
    long lOutput;
    // Update the error integrator.
    if((psState->lIntegrator & 0x80000000) == (lError & 0x80000000))
        // Add the error to the integrator.
        psState->lIntegrator += lError;
        // Since the sign of the integrator and error matched before the above
        // addition, if the signs no longer match it is because the integrator
        // rolled over.  In this case, saturate appropriately.
        if((lError < 0) && (psState->lIntegrator > 0))
            psState->lIntegrator = psState->lIntegMin;
        if((lError > 0) && (psState->lIntegrator < 0))
            psState->lIntegrator = psState->lIntegMax;
    else
    // Saturate the integrator if necessary.
    if(psState->lIntegrator > psState->lIntegMax)
    if(psState->lIntegrator < psState->lIntegMin)
    // Compute the new control value.
    llOutput = (((long long)psState->lPGain * (long long)lError) +
                ((long long)psState->lIGain *
                 (long long)psState->lIntegrator) +
                ((long long)psState->lDGain *
                 (long long)(lError - psState->lPrevError)));
    // Clip the new control value as appropriate.
    if(llOutput > (long long)0x7fffffffffff)
        lOutput = 0x7fffffff;
    else if(llOutput < (long long)0xffff800000000000)
        lOutput = 0x80000000;
    else
        lOutput = (llOutput >> 16) & 0xffffffff;
    // Save the current error for computing the derivitive on the next
    // iteration.
    psState->lPrevError = lError;
    // Return the control value.
    return(lOutput);
Unread 17-01-2012, 19:10
No... it's not GetFaults() that you want... it's GetError(). You can call StatusIsFatal() to get a boolean for if there is an error or not. GetError() returns an "Error" object (Error.h) that you can call a number of methods on if it is an error. It is generally good practice to always check for an error after every call to a CANJaguar object so you know if you can trust the data that is returned or if the command you sent was acknowledged by the Jaguar. If you get an error that is not "Time-out", the CANJaguar object will stop trying to talk to the device, since the calling code is clearly broken. This is likely what is happening in your case. If you get an error and you want to continue talking to the device, you can call ClearError() to try again. You should also call ClearError() if you get a time-out so that you can tell if there is a timeout from a future call.
I clearly need to write some examples for using CANJaguar in C++. Feel free to contribute some if you like.
-Joe
Unread 17-01-2012, 19:11
mikets's Avatar
Software Engineer
Ah, I see what you meant. You meant the error in the console. Yes, it indeed complained that I can't call SetPID while the Jag was in PercentVbus mode. But why the limitation?
ERROR: The object is in an incompatible mode: PID constants only apply in Speed, Position, and Current mode ...in SetPID() in C:/WindRiver/workspace/WPILib/CANJaguar.cpp at line 539
Unread 17-01-2012, 19:13
The limitation is because if your code thinks it's a good idea to call SetPID when not in a closed-loop control mode, you probably need to be made aware of that and fix your code before expecting it to function properly.
