| Thread Tools |
Rating:
Display Modes |
Error Deploying JAVA
We are having an issue when we try to deploy our code. We get two lines of errors:
[crio] task 0x2869fd8 (mdns resolve) deleted: errno=0 (0) status=0 (0) [crio] task 0x2bff138 (mdns resolve) deleted: errno=0 (0) status=0 (0) Then the process just stops and we get solid act/link lights on both the crio and the bridge and the PC What are we doing wrong? |
Hey guys,
We are desperate. Three night and our rookie team is dying here. We need some help from the experts. |
Re: Error Deploying JAVA
Were there any other messages in the console window?
Can you verify that you can ping the cRIO? You should open a CMD window on your PC that is connected to the robot and type "ping 10.x.y.2" where x.y are your team number. If you don't get a response, there is a connectivity problem. You might also try to disable the windows firewall on your system to see if that helps. Let us know what happens after you try those things. |
are you sure that all the dip switches are off?
Yes we can ping the crio and the pc itself. The dipswitches are all electronic and are set off in the flashing utility. We even reflashed with the image a second time in case it was corrupted. I printed a copy of some other people's error messages and it appears we are not even starting to load the code. My programming teams thinks they may have forgotten to install or update a couple things. We are also istalling all the software on the Classmate to assure it is not a laptop issue.
We did a quick build on Saturday and it actually created more issues than if we followed the step by step instuctions. If you have any other suggestion, let me know and I'll post back tonight with any updates and post the entire output file. Thanks, Guys |
Hi Steve,
Our rookie team is treading same waters. We may have a corrupted Crio and of course we cannot deploy our java code. If your team was able to get it worked, can you let us know how to's? Note: Yesterday some of our team members fried two of the jaguars ... It is still going though cheers, George |
#7
Are you able to see the robot via the driver station software?
#8
OK guys, here's the whole log file for the build and run. This the default sample code from the getting started with java.
Please review and help!!! init: init: Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Deleting directory C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\j2meclasses clean: Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build Compiling 1 source file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\build compile: Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\j2meclasses preverify: Created dir: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Building jar: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite\RobotTemplateFirstDrive1_1.0.0.jar jar-app: CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods [translating suite image [closed: false, parent: squawk] ...] ### Excluding compile: com.sun.squawk.Method::getParameterTypes ### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt [Including resource: META-INF/MANIFEST.MF] Romizer processed 96 classes and generated 4 files. Expanding: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite\RobotTemplateFirstDrive1_1.0.0.jar into C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Moving 1 file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Moving 1 file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Moving 1 file to C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\suite Deleting: C:\Users\Teacher\Documents\1-FirstTeam4055\RoboticPrograms\RobotTemplateFirstDr ive1\image.suite.api Host OS: Windows 7 6.1, 6.1 Host JVM: Java HotSpot(TM) Client VM 20.5-b03 Target IP: 10.40.55.2 Network interfaces on host: Realtek PCIe GBE Family Controller: address: 10.40.55.6 netmask: 255.255.255.255 or hidden by IPv6 address (due to Java on Windows Bug:6707289) Connecting FTP @10.40.55.2 upgrade: Sending local file image.suite flashapp: deploy: debug-run: do-debug-run: [cRIO] [OTA Server] ********* REBOOTING cRIO ********* [cRIO] Waiting for cRIO to reboot (1s) Waiting for cRIO to reboot (2s) Waiting for cRIO to reboot (3s) Waiting for cRIO to reboot (4s) Waiting for cRIO to reboot (5s) Waiting for cRIO to reboot (6s) Waiting for cRIO to reboot (7s) [cRIO] Connect debugger attempt 1 Connecting NetBeans debugger Start debug proxy init: CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods Trying to connect to VM on socket://10.40.55.2:2800 Attached JPDA debugger to localhost:2900 Failed to establish connection with VM: Connection refused: connect - trying again in 5 seconds... [cRIO] -> * Loading debug.o: debug [cRIO] Debugging is up, target server mounted at /tsfs [cRIO] [cRIO] [cRIO] VxWorks [cRIO] [cRIO] Copyright 1984-2006 Wind River Systems, Inc. [cRIO] [cRIO] CPU: cRIO-FRC II [cRIO] Runtime Name: VxWorks [cRIO] Runtime Version: 6.3 [cRIO] BSP version: 1.0/0 [cRIO] Created: Jun 2 2011, 16:29:00 [cRIO] ED&R Policy Mode: Deployed [cRIO] WDB Comm Type: WDB_COMM_END [cRIO] WDB: Ready. [cRIO] [cRIO] * Loading nisysrpc.out: nisysrpc [cRIO] * Loading NiRioRpc.out: NiRioRpc [cRIO] * Loading nivissvc.out: nivissvc [cRIO] * Loading nivision.out: nivision [cRIO] NI-RIO Server 4.0.0b8 started successfully. [cRIO] task 0xeb6cf8 (NiRioRpc) deleted: errno=0 (0) status=0 (0) [cRIO] * Loading visa32.out: visa32 [cRIO] * Loading niserial.out: niserial [cRIO] * Loading sysstatepublisher.out: sysstatepublisher [cRIO] task 0xfc9b00 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0) [cRIO] task 0xff2178 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0) Trying to connect to VM on socket://10.40.55.2:2800 [cRIO] task 0x163af30 (ServerAds.Lookup) deleted: errno=0 (0) status=0 (0) [cRIO] * Loading RTWebServer.out: RTWebServer Failed to establish connection with VM: Connection refused: connect - trying again in 5 seconds... [cRIO] System Web Server started [cRIO] * Loading NiFpgaLv.out: NiFpgaLv [cRIO] task 0x25f3f20 (tNiDsc0) deleted: errno=13893648 (0xd40010) status=0 (0) [cRIO] * Loading FRC_FPGA.out: FRC_FPGA [cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication [cRIO] FRC_NetworkCommunication was compiled from SVN revision 2923 Trying to connect to VM on socket://10.40.55.2:2800 Failed to establish connection with VM: Connection refused: connect - trying again in 5 seconds... [cRIO] FPGA Hardware GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C [cRIO] FPGA Software GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C [cRIO] FPGA Hardware Version: 2012 [cRIO] FPGA Software Version: 2012 [cRIO] FPGA Hardware Revision: 1.6.4 [cRIO] FPGA Software Revision: 1.6.4 [cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM [cRIO] [cRIO] [cRIO] [OTA Server] Version: 2012 FRC, Jan 5 2012, 17:20:48 [cRIO] [cRIO] [cRIO] Welcome to LabVIEW Real-Time 11.0rc14 [cRIO] task 0xeaea58 (sysapi-rpc) deleted: errno=0 (0) status=0 (0) [cRIO] [cRIO] [Squawk VM] Version: 2011 FRC, Nov 5 2011, 14:34:13 [cRIO] [Squawk VM] File SQUAWK_DEBUG_ENABLED found, starting squawk in debug mode... [cRIO] Listening for connection from proxy on serversocket://:2800 Trying to connect to VM on socket://10.40.55.2:2800 Established connection to VM (handshake took 16ms) [cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c [cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9 [cRIO] DIO LoopTiming: 260, expecting: 261 Waiting for connection from debugger on serversocket://:2900 [cRIO] task 0x25b3c80 (System Web Services Load Thread) deleted: errno=0 (0) status=0 (0) [cRIO] task 0x2856198 (mDNS resolve) deleted: errno=0 (0) status=0 (0) [cRIO] task 0x2beb2f8 (mDNS resolve) deleted: errno=0 (0) status=0 (0) |
#9
After attempting to deploy, you should be able to open the driver station software and see if it shows you having any code on your robot.
#10
Try hitting the "play" (green triangle) button rather than the debug button. It looks like its a debugger issue and not a deployment issue. I think you can also use F6.
Brad |
#11
Did you try connecting the Debugger? See the instructions starting on the bottom of page 9 of Getting Started with Java (or run the program without debugging the way Brad posted above)
#12
We get the same error whether we run in debug mode or not. Happens on both development laptops as well as the classmate. After we perform this procedure we get the connected light and robot code light in driver's station but the jaguars do not go solid green and nothing happens.
#13
Actually, the status code of 0 at the end of your previous log is not an error. Are you sure that your program isn't deploying? Is it possible that the program just has an error in it and isn't doing what you're expecting?
Can you try one of the default programs like the simple robot template, and put in some print statements and see if anything comes out on the console? Also, you might want to take out some of the motor code to make it easier. Brad |
#14
What you're seeing is not an error.
Have you tried Enabling the robot with the Driver Station? Did you rework your DB-37 cable? What is the light next to the 2 pin header on the Digital Sidecar doing? Are all 3 lights on the Digital Sidecar brightly lit? |
#15
Sounds like a good idea to me.
