Go to Post I think this says it all... It's Fantasy FIRST on Chief Delphi. - Zach O [more]
  #61   Spotlight this post!
Unread 09-01-2012, 17:11
Bob Steele's Avatar
AKA: Bob Steele
Re: Strategies for Rebound Rumble
Originally Posted by slijin View Post
Just as a note - although this already has been raised in various other threads - the dimension constraints also physically limit you from extending the robot sufficiently close enough to the hoops to contact them.
Perhaps aiming at a certain point on the rim to bounce the ball in would work - FIRST must've replaced the springs for a reason.
i don't think you could touch the basket. It is a height limit...
You will still be limited to going outside the frame perimeter ..
You are allowed a single projection of 14" ... with a 3" bumper your projection is only 11" outside the robot bumper.
The unit at the bottom of the baskets extends 38" approximately from the wall.
So your frame perimeter is approximately 41" from the wall.
With a 14" extension that would mean that you would be 41" - 14" = 27" from the wall...
I am not sure how far the hoops stick out... but with a 20" circular hoop and its associated hanger it is pretty close.
i would imagine that the game planners figured this out pretty well so that touching the hoop would not be possible.
Obviously no matter what size the hoops are... no one could EVER touch the top hoop...(it is beyond the allowable height...
  #62   Spotlight this post!
Unread 09-01-2012, 22:13
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Big strategy = ball control.
Your inbounders hold their 2 balls each, your robots hold their 3 balls each, and suddenly the opposing alliance is ball starved to only 3.
you keep one robot right in the alley to shoot back across the court whenever an extra ball is scored and an inbounder has to let one go.
Thus each time the opposing alliance scores they have to drive all the way across the court to get the ball again.
Balance for bonus points and the win assuming your opponents cant.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
  #63   Spotlight this post!
Unread 09-01-2012, 22:18
Andrew Lawrence
Posts: n/a
I think the better strategy is robot control if a good defensive robot is able to keep the opposing team on their side of the bumper, while picking up balls rom the key and shooting them back at their alliance, their alliance members will be free to pick up the balls from the opponent's key, and score again, creating and endless loop of scoring and restoring. Now 3v1 would be hard on the defending robot, so maybe 1 big scorer that does the repetitive scoring and 2 defensive robots. Once you get over the bump/bridge, it becomes easier to stop others from doing it. Plus, you can practice ball starvation that way.
  #64   Spotlight this post!
Unread 09-01-2012, 22:30
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Weaknesses in this strategy:
1> when your opponent scores you also are assessed a foul because you now have a ball in the corral that none of your inbounders can immediatly take (they each have 2)(and even if 1 of the inbounders enters a ball onto the field they will be out of position to immediately take a ball from the corral).
2> The recieveing robot is in your opponants alley, and if contacted (regardless of who initiates the contact) will incur a foul.
3> you assume your opponant cannot balance ... I'd not make that assumption.
___________________
- Tennyson, Ulysses
  #65   Spotlight this post!
Unread 10-01-2012, 16:36
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
The problem with this strategy is what you will do with these balls once you have them. Either you end up starving yourself, being forced to let go of a ball, or you try to score – which puts the balls right back into the opponent's hands. And that's not including the other 3 balls that you can't control.
That being said, this idea is still very useful as a delaying tactic.
  #66   Spotlight this post!
Unread 10-01-2012, 17:13
Yes you starve yourself as well, but this strategy is more for a team that is playing against high scoring bots, and likes their chances better at relying on ramp points.
  #67   Spotlight this post!
Unread 10-01-2012, 18:11
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I believe the secret is actually in the coopertition bridge. If you create a robot that can line itself up on the bridge and it would be right in line to score. Also, by remaining on that bridge for periods of time, the opposing alliance can only use their own bridge. Also, towards the end of a match, you're already where you need to be to possibly score coopertition points!
  #68   Spotlight this post!
Unread 10-01-2012, 18:21
trissinata trissinata is offline
FRC #1111
trissinata is an unknown quantity at this point
Originally Posted by Tetraman View Post
It was shot down in our meeting, so here is my idea:
Make a robot with a ramp allowing another robot to drive on top of you, and you then solve the problem of how to get 3 robots on the bridge. Also, you can use it with your opponent's robot so you and your opponent can easily balance on the Coop bridge together as one entity rather than two.
Our team 1111 tried that i believe 2 years ago, it did not work at all, but if your team could pull it off, with enough time after and before your done making it to calculate the proper weight distrapution it might work. An arm to keep it down might also work.
  #69   Spotlight this post!
Unread 10-01-2012, 19:34
magi65's Avatar
magi65 magi65 is offline
AKA: Adam Norris
FRC #3284 (LASER)
Team Role: Scout
magi65 is an unknown quantity at this point
Originally Posted by Daniel_LaFleur View Post
I'd defend the bump in the middle and keep my opponents from reloading, which will force their inbounders to put the balls into play on our side of the field without a robot there to pick them up.
According to [G23] Robots on the same Alliance may not work together to blockade the Court in an attempt to stop the flow of the Match.
Mwa hahahahahaha
Don't join the dark side, they don't have cookies
  #70   Spotlight this post!
Unread 10-01-2012, 21:00
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Our team was thinking of just waiting underneath the hoops on the opposing alliance's side. This way, for all the balls that are missed, they could fall into a funnel on our robot that would focus them into a launching device and shoot them back onto our side.
So based on this idea, is our robot allowed to remain in front of the hoops for the whole match as long as it is under five feet?
  #71   Spotlight this post!
Unread 10-01-2012, 21:07
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
Yeah, you're allowed to do this. But make sure you have a way of stopping the balls from entering the funnel. Once you get more than 3 balls its a foul. And the other alliance gains points.
For EVERYONE- not matter defense or offense- make sure you have a way of picking the ball off the ground. Even the most perfect robots will miss the shots from different angles- its a great chance to get rebounds and get some easy points!
College Student | "It won't fail because of me."
  #72   Spotlight this post!
Unread 11-01-2012, 02:11
SniperJoe101's Avatar
SniperJoe101 SniperJoe101 is offline
FRC #1678 (Citrus Circuits)
SniperJoe101 is an unknown quantity at this point
I love the idea of coopertition but honestly I believe the best way to score points is 3 robots on the alliance bridge. Obviously during qualifying it would be very hard to do but once in elimination you have an established alliance. You can then focus on finding the correct way to balance all 3 bots and score 40 points. That could easily turn the tides of any match. Especially when this year's game is so reliant on an accurate shooter for high scoring matches. One thing that Im going to bring up with team 1678 is to make a computer program which you just input the weight and some other values into it and it outputs a configuration for all 3 bots.
Another strategy I have thought of is to have a bot sit right at the inbound station and pretty much have the inbounder hand load the bot which then fires the balls across the court and to the other alliance members. This would help keep from ball starvation and allow the inbounder to be more effective.
  #73   Spotlight this post!
Unread 11-01-2012, 05:45
MikeReilly's Avatar
MikeReilly MikeReilly is offline
FRC #4509 (Mechanical Bulls)
MikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud of
For Rookie Teams: consider making a very small bot that can easily squeeze onto a bridge as the 3rd, and can herd balls to your alliance, or maybe flip them over the barrier. This will make you a very desirable 3rd pick for Eliminations.
Mentor for Rookie Team 4509, Formerly with 1771
  #74   Spotlight this post!
Unread 11-01-2012, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
Also think about the three offensive robots, each up to 84" tall, right next to each other in the key shooting at baskets: Will you be able to shoot past or over them to get balls back onto your side?
  #75   Spotlight this post!
Unread 11-01-2012, 21:57
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
It seems like you might be confusing the scoring systems a bit. The coopertition bonus only applies during qualifying matches, where it is worth as much as a win; getting 40 points for balancing 3 robots only applies during eliminations (otherwise it is worth the same 20 points as balancing 2 robots).
Does anyone else remember when TBA signatures actually worked?
