Go to Post There is no shame in admitting someone is better than you at something doesn't make them a better person just means they have skill you haven't figured out yet. The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
View Poll Results: What kind of chassis are you building?
Wide Chassis (longer side in front) 139 44.27%
Narrow Chassis (smaller side in front) 175 55.73%
Voters: 314. You may not vote on this poll
Unread 11-01-2012, 10:52
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Re: Poll: Wide or Narrow Chassis?
We are going wide
we are somewhat worried about tipping when attempting the bum so we are trying to create some kind of Wheely Bar so we dont tip
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 11-01-2012, 11:10
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
I'm guessing narrow, but not sure yet. Feels like it would allow for a more convenient placement of the control board as related to ball intake.
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 11-01-2012, 11:21
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by SuperNerd256 View Post
I see no need to pick up balls faster, since you can only hold 3 balls at a time.
The speed with which you can collect balls kind of depends on the ease with which you can collect balls. Since there won't be a lot of balls on the field if the Inbounders are playing smart, then you probably want to make ball collection as easy as possible. A narrow robot leaves a very small area to collect balls, if you are using just an opening between the bumpers. Consider that you'll be driving the robot from a long distance away, so it will be hard to see just what you're doing, and getting an 8" ball into a 12" wide opening under those conditions is going to be quite a challenge. An alternative is to make a wide ball collector that hinges out/down, but this presents some different problems.
I like how the trade-offs in this game are so well balanced, it's difficult to decide which is the best way to go. Look at the poll results so far...
Unread 11-01-2012, 21:54
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Sconrad View Post
Are you proposing that Bots 1 and 3 have their lighter side hanging off of the side of the ramp?
Yes, that is correct
Originally Posted by Tristan Lall View Post
Bah. Line them up across the edge of the bridge, and I'll push them up sideways with my robot.
We are seriously considering just that.
Originally Posted by soxfan269 View Post
Our team came to the conclusion that if you ever see three on a ramp that will be the only time you see it.
I then conclude your team is not planning on making it to Einstein this year.
Originally Posted by karomata View Post
in support of a wide drive because it can collect balls faster
Wide doesn't mean fast. Or easy. Do not limit yourself to a gap in your frame for a ball collection device. You can have an arm that swings down, using the same principle used to collect tennis balls quickly, for example. (like this shows starting at 0:19)
Originally Posted by viperred396 View Post
we are somewhat worried about tipping when attempting the bump
Focus very intensely on a low center of gravity. Our 'Breakaway' robot was called Weeble - can you guess why?
Yes, exactly. And teams should realize that most balls will be against a wall, so if your BAD* cannot pick up from against a wall, it will not be very useful. You need a good BAD.
(*BAD = Ball Acquisition Device)
Unread 11-01-2012, 22:08
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Honestly, I have no idea what orientation to call our drive.
The reason is because we're doing something... weird, to say the least. We have decided that we will be using Mecanum drive as the base, with the BAD* situated on the long side. However, assuming that is the front, our wheels will NOT be pointing in that direction. Rather, they will be oriented the long ways, allowing us to have the stability of the long orientation and the ball carrying capacity of the narrow orientation. Best of both worlds really.
Except maybe for having to deal with drifting. But that's a software problem.
*Ball Acquistion Device as dubbed by DonRotolo.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 11-01-2012, 22:12
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
i would go narrow... you might have problems getting over the middle with a wide front, unless you have crab/swerve, or some other types of multi-directional drive trains. unless of course you have an low cg, etc. plus you're not really doing mass collection of game pieces
Unread 11-01-2012, 22:15
minidave910 minidave910 is offline
FRC #0910
minidave910 is an unknown quantity at this point
I can tell you that my team is leaning towards wide right now and the main point is this: ease of picking up balls. I know you are all arguing that with so few balls on the field we won't need to be able to pick up fast but I believe that fast isn't what the teams going with wide are looking for, we are looking for ease of use. We want something like many of the gatherers last year (33 is a good example) where we can just drive up to a ball full power and pick it up without any fine alignment, almost as if we have some magic vacuum at the front of the robot. Plus there is always fitting on the ramp...
P.S. I love the term BAD and am going to start using it whenever possible.
Unread 11-01-2012, 22:34
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
SQUARE. Meccano wheels actually work best with the rollers forming a "perfect" X. That is, the wheels should be in a square, hence square frame (Ether can verify this, I found some white papers of his but I'm too lazy right now to find 'em again.). It doesn't matter which end is front, but one end will have to be the front regardless. You can't swap a hole in the frame halfway through a match!
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 11-01-2012, 22:37
Elgin Clock's Avatar
FRC #0237 (Black Magic)
What a difference a day makes.
The last time I looked yesterday, long config was wining the poll ~60% to ~40% but now only ~51% to ~49%.
Interesting.
Unread 11-01-2012, 22:40
DonRotolo's Avatar
Back to humble
FRC #0832
Interesting.
I think that as more experienced teams answer, we see folks who are not afraid to leave their comfort zone.
Unread 11-01-2012, 22:58
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Not on a team currently, but if it was my bot I would go wide with a 14" wheelie bar that was retractable and also function as a bridge tipper.
Unread 11-01-2012, 22:59
MrForbes's Avatar
AKA: Jim
Square where the wheels contact the floor? or square at the outside of the frame?
Unread 11-01-2012, 23:01
Andrew Lawrence
Posts: n/a
I think it only matters where the wheels contact the frame. One would just build the robot square as well to make it less likely to tip, or to make it look better.
Unread 11-01-2012, 23:12
Optimist Alumnus
AKA: Nathan
DonRotolo, you are a genius BAD is so good xD
On a more serious note to the people considering wide chassis for the potential for a wider BAD™, a word of caution. I had a bit of experience with working on a BAD™ and conveyor system a few years back. It is CRUCIAL that if you make your BAD™ wide, you have some way of funneling balls down to a more narrow path for whatever your scoring device is (unless your scoring device is very wide, though I'm not expecting many of those this year). The worse possible feeling in the world is building an excellent BAD™ and the game pieces getting jammed because the robot has no good way to shunt the pieces into single file.
Unread 11-01-2012, 23:14
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Wow, this is a really neck-in-neck poll.
Our team is going wide, for the same reasons that have been made. We want to be able to fit 3 robots on the bridge, and decided this just to stay on the safe side. Another factor that has also been said before, is more room for a ball herder. Maybe not so we can pick up more balls at a time, but so we have more room to work with while it's being built/maintained.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
