Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 11-01-2012, 19:15
jetdog6 jetdog6 is offline
FRC #1662
jetdog6 is an unknown quantity at this point
middle line in key
From looking at the pictures of the field for 2012, it looks like there is a line in the middle of the key. I cant find any documentation on this line though to make sure that it will be there at competition. Does anyone know anything about it? It looks like it might be a line between the two plates that create the key. Thanks!
Unread 11-01-2012, 19:17
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: middle line in key
You are correct it is just the line between the two plates.
1058 PVC Pirates 2016 - xxxx
Unread 11-01-2012, 19:18
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
The key is actually two quarter circles velcroed by each other so thatis the line between them.
Unread 11-01-2012, 19:32
FRC #1662
Will the velcro between them always be black? I am hoping to follow this line with line followers. As long as there is some sort of difference between the velcro and the carpet around it I should be able to pick it up with the line followers im assuming.
Unread 11-01-2012, 22:20
The velcro is very likely to be black, but it is on the bottom of the HDPE to hold it to the carpet, and will almost certainly not be visible. The "line" between the two halves of the key is just a seam.
Unread 11-01-2012, 22:28
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Why would you want to line follow down the key?
You can start anywhere touching the key, under [G01], so you could just start at the close end of the key.
Kettering Motorsports
Unread 11-01-2012, 23:19
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Auto aiming in teleop
