Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Unread 11-01-2012, 20:35
teklingl teklingl is offline
FRC #3770
teklingl is an unknown quantity at this point
Trouble imaging cRIO II
Going through the recommended steps for imaging the cRIO II. While running imaging app, process either hangs up or we receive following error.
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlibialog.vi
Imaging tool does "see" cRIO - verifying network between PC and device OK.
Any thoughts would be appreciated. Thanks.
Unread 11-01-2012, 21:23
leeboy1312 leeboy1312 is offline
FRC #4021
leeboy1312 is an unknown quantity at this point
Re: Trouble imaging cRIO II
I have also had a problem with the crio if someone could post a link of a step by step on how to set it up it would be very helpful thanks.
Unread 11-01-2012, 22:33
There are already numerous threads about this, containing detailed suggestions on what to try and what has worked for other teams. Please use the Chief Delphi search feature. The error code or the "nisyscfg.lvlib" keyword would be a good term to search on.
Unread 11-01-2012, 23:37
Here's a quick list of threads about cRIO connectivity, imaging, and uploading files. There's some great advice here from CD longtimers Joe Hershberger, Joe Ross, Mark McLeod, Alan Anderson, and others. Worth reading:
Cannot download files into the cRIO
http://www.chiefdelphi.com/forums/sh...ad.php?t=99824
cRIO Imaging Tool trouble
http://www.chiefdelphi.com/forums/sh...ad.php?t=99784
cRIO updating to v43 Image issue
http://www.chiefdelphi.com/forums/sh...ad.php?t=99585
Problems with cRIO
http://www.chiefdelphi.com/forums/sh...ad.php?t=99747
2012 FRC crio imaging tool
http://www.chiefdelphi.com/forums/sh...ad.php?t=99515
Imaging tool for the new 4-slot cRIO
http://www.chiefdelphi.com/forums/sh...ad.php?t=99157
2012 cRio 2 cannot be found
http://www.chiefdelphi.com/forums/sh...ad.php?t=99671
Setting up FRC cRIO II?
http://www.chiefdelphi.com/forums/sh...ad.php?t=99615
Help with cRio II
http://www.chiefdelphi.com/forums/sh...ad.php?t=99826
FRC cRIO II
http://www.chiefdelphi.com/media/papers/2588?
paper: FRC cRIO II
http://www.chiefdelphi.com/forums/sh...ad.php?t=97702
