| View Poll Results: What kind of chassis are you building? | |||
| Wide Chassis (longer side in front) |
139 | 44.27% |
| Narrow Chassis (smaller side in front) |
175 | 55.73% |
| Voters: 314. You may not vote on this poll | |||
Re: Poll: Wide or Narrow Chassis?
I think it only matters where the wheels contact the frame. One would just build the robot square as well to make it less likely to tip, or to make it look better.
DonRotolo, you are a genius
BAD is so good xDOn a more serious note to the people considering wide chassis for the potential for a wider BAD™, a word of caution. I had a bit of experience with working on a BAD™ and conveyor system a few years back. It is CRUCIAL that if you make your BAD™ wide, you have some way of funneling balls down to a more narrow path for whatever your scoring device is (unless your scoring device is very wide, though I'm not expecting many of those this year). The worse possible feeling in the world is building an excellent BAD™ and the game pieces getting jammed because the robot has no good way to shunt the pieces into single file. |
Both. But at the moment i'm not totally sure what the mech guys are doing. All I know is that I'm tryng to prevent them from bashing up the encoders on last years bot as we dismantle it.
Looking at the earlier calculations on whether three long robots could actually fit on the bridge, one little fact was overlooked. Three 38 inch long robots can fit on the ramp, indeed. But a robot built to its maximum dimensions will not be 38 inches, but rather more like 44 inches. Why? The bumpers are not included in the 38 inch measurement, so when you take into account the extra bumper space, you're going to have a little bit more robot hanging over the edge than you think.
The balance issue with a tall robot can be easily overcome. The simplest solution is to put the center of balance towards the bottom of the robot. With that, it will be much easier to avoid tipping. And a sideways robot can allow all three robots, even if the other two are long ways, to fit comfortably. With that, long ways will be the best way in my opinion, because as we all know, every little second counts, and that second saved collecting that extra ball can give you those few extra points that you need to win nationals. ![]() |
That said, 3 long bots definitely does create a very precarious situation! It's certainly something to think about, though I think you'll find that virtually all teams otherwise likely to be strong elimination contenders will have realized this (and likely the benefit to collecting width-wise) and found a way to compensate. I won't claim this necessarily means driving wide. Low CG is definitely always something for which to aim. (Unless the GDC ever forgets to specify the height dimension as being perpendicular to the floor. ) However, I can't claim it's necessarily easy to achieve. It definitely can be if you have a non-existent scoring mechanism, an exceedingly light/low shooter, or Andy Baker. Us tall shooters will being paying very, very close attention to it.Welcome to ChiefDelphi! |
#7
Ah, I hadn't read past the first page. But thank you, I've used this site now for a long time, but just now signed up.
#8
Well, it has happened: The wide chassis count has surpassed the narrow chassis one.
#9
We, the long chassis voters, are now the minority that can, in the end, tell the majority "I told you so". (At least, I hope so.
#10
I agree haha. Grabbing a ball in 11" (I believe thats what we calculated would be the space allotted for bringing in balls according to bumpers being 8" from either end or w.e) space on the narrow end just won't be enough. Using the wide side, you won't have to worry about that. You'll have plenty of space to grab a ball and bring it inside the bot without thinking about it in the heat of the game.
#11
http://www.youtube.com/watch?v=bI_2UMEUbNw"]http://www.youtube.com/watch?v=bI_2UMEUbNw |
#12
) seems to me to be an extremely difficult, if not impossible. I hate to be close-minded, but I tend to side with soxfan269. If we see three long robots on a ramp, it will most likely be a monumentous, if not one-of-a-kind, event. |
#14
A wide robot on the bridge only partway would likely be a 4 wheel robot, with one pair of wheels hanging off the edge and the frame (or chains?) resting on the edge of the bridge deck, which is a relatively stable configuration
#15
We have decided to go with narrow body. We, as a team have decided that is very important to go over the barrier. A wider robot has a higher center of gravity, as compared to a narrow one.
The main point is a wider base means a likely chance of your robot taking a dive. Last edited by Henzado : 12-01-2012 at 23:05. |
