Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 11-01-2012, 23:05
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Mecanum on the bridge?!
Not to rain on people's parades here, but.....
***Before I go on, I feel I need to point out that I do have experience with Mecanums. 2 years. 1.5 years driving***
  • In that first video, some on the other side is holding the ramp up (or down, however you look at it). Now, I can't prove it, but I'm pretty darn sure that that helps the robot get up.
  • It took a long time to get up that ramp. Too long.
  • 1 out of 5 times that drivetrain will probably fall off, unless you go super slow, which in that case see Bullet point #2
  • What happens if for some reason you can't go over the bridge that round? Mecanum's will have an extremely hard time maneuvering the ridge.
  • The material on that bridge was different than that of in the real game
  • In the second video, the Mecanum's were having a very hard time getting up the bridge (not too sure how it helped Mecanum's case). If anything, it shows that carefully done programming will be required just for your drivetrain.
  • The more top heavy these robots become, the harder it will get.
  • A preponderance of team's this year will have a strong hard pushing robot. Good luck scoring on one. It's not fun.
Please take my criticism in a constructive manner, as I will do the same.
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 11-01-2012, 23:06
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Originally Posted by richy0101 View Post
Our team tested our mecanum wheels from last year on the bridge and it was able to go over it perfectly. As for the bump, I think that would be only be possible with shocks.
Nope, that was another thing we tested on Monday besides balancing the bridge. A robot can go over with 8" wheels. Granted, I have no idea how it would react to slamming straight into it full speed ahead, but then again, I have no idea how any other drive train would do in comparison as well.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 11-01-2012, 23:08
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Much better, for the most part.
Unread 11-01-2012, 23:23
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
-Duke
  • I was holding the opposite end of the bridge up to allow the robot on because it doesn't have a lowering mechanism (last year's bot). The robot moved under its own power the entire time.
  • There's uneven friction on the mecanums and the fiberboard is ~3x more slippery than the actual Lexan surface, so it takes longer to drive up.
  • The drivetrain will not fall off the robot (if that's what you meant), nor will the robot drive off the edge if there's a careful driver.
  • Not really. Mecanums still have good grip on the surface of the bridge.
  • Not my robot, so I don't know what's up in that video.
  • That applies for every robot, too.
  • I can't see how that's applicable specifically to mecanums.
Hope this helps.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 12-01-2012, 01:33
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
[*]It took a long time to get up that ramp. Too long.
Slippery surface, high CoG robot, early test. Our tests show it doesn't take nearly that long.
[*]1 out of 5 times that drivetrain will probably fall off, unless you go super slow, which in that case see Bullet point #2
The bridge has more than enough maneuvering room; if you fall off it's because you drove really badly.
[*]What happens if for some reason you can't go over the bridge that round?
Find me an opposing robot blocking your bridge and I will find you a nine-point technical foul. Besides, bridge traffic is likely negligible.
Mecanums will have an extremely hard time maneuvering the ridge.
Mecanums can have wheel guards and wedges built in, same as any drive.
[*]The material on that bridge was different than that of in the real game
But it had less friction.
[*]A preponderance of team's this year will have a strong hard pushing robot. Good luck scoring on one. It's not fun.
Score from the key.
Unread 12-01-2012, 16:23
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Mecanum wheels have real world applications. Airtrax has video of their forklifts climbing stairs and bumps with them. With the appropriate size wheels and design, i'm not sure why there is a debate.
Unread 12-01-2012, 16:25
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Hopefully im not making this too much of a back and forth argument.....
Hope this helps.
  • I know, but i think the fact that the bridge isn't going to move no matter what helps the robot. Not too sure, so let's drop that one.
  • Again, not an expert on this aspect, but I think Mecanum's act differently in that they need less friction ( or more friction) than most wheels to work properly. I'll conced this since i can't really support that.
  • I meant the entire robot, sorry for the confusion. And notice you said IF the driver drives carefully. Please note again my original second point on how long it will take, and how driving carefully lengthens the time. In addition to this, other factors besides careful driving can affect this. And no, it does not have to be done in the means of a technical foul.
  • Again, I can't mathematically support my claim, so i will concede this.
  • Not everyone has your robot either. I made this point as a generalization for Mecanum', not necessarily yours in particular.
  • Correct, but wheels that have higher friction (e.g., pneumatics) will mitigate the CoG issues.
  • I don't know if you've ever played offense in a real match with mecanums with a decent defender. But I have. And for a good defender to push you around is as easy as beating a 2nd grader in basketball.
Round two.
Originally Posted by ThirteenOfTwo View Post
  • Slippery surface, high CoG robot, early test. Our tests show it doesn't take nearly that long.
  • The bridge has more than enough maneuvering room; if you fall off it's because you drove really badly.
  • Find me an opposing robot blocking your bridge and I will find you a nine-point technical foul. Besides, bridge traffic is likely negligible.
  • Mecanums can have wheel guards and wedges built in, same as any drive.
  • But it had less friction.
  • Score from the key.
  • I disagree. Too long. (stalemate here)
  • Not true at all. Many factors determine driving--jjust one of them is the driver's skill. There's no reason to rely on the driver's skill when designing a robot.
  • Find me a Regional with every robot code working properly and I will find you the 2013 FRC Water Game Designs. You not making it onto the bridge is not exlusive to technical fouls.
  • Why overdesign when you can use other wheels that don't need these ridges? Have you proven yet that these wedges will be effective enough? (In no way am I saying it can't be done.)
  • See my earlier point higher in this post. I will concede this.
  • Why are assuming you will always be on the key? If I were a defensive driver, there would be plenty of way i could keep you off the key, directly and/or indirectly.
-Duke
Unread 12-01-2012, 21:27
College...
No point in continuing to argue this one, we just disagree. We'll see once I've got [S]better[/S] prototypes on my end.
Maximum width of robot including bumpers is 36 inches. Maximum wheel-to-wheel distance is more like 26. You have more than a foot of room to misaim... if you fall of the bridge in the process of crossing it, your driver did something horribly wrong, no matter how good your software is.
So, uh, you're saying that we could be blocked from crossing the bridge if two robots independently break down in front of two separate bridges and are too heavy to be pushed out of the way? The odds of that are so negligible that it's hardly worth discussing.
Or you could just not design for the ridges. It's not like they're necessary to cross for most robots. (If all three robots on an alliance are regularly crossing midfield, think of the time wasted!) I haven't tried the wedges, but I'm 99% sure they'll work. Remember, any drive built to cross the ridge needs an elevated chassis to avoid high-centering anyways, so all you're adding is extra metal plates.
I'm not assuming you'll be there, I'm saying you can get there. Maybe there have never been good tank drive defense robots at my regional, but I kind of doubt that. Pushing mecanum drives is indeed fairly easy, but it's not pushing them around that's the hard part of defense, it's maintaining the push.
Unread 12-01-2012, 22:34
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
I'm too lazy to continue this argument, and frankly, it's stupid to continue it. You'll find out once you play with Mecanum's this year.
Can't say i didn't try.
-Duke
Unread 12-01-2012, 22:59
MikeBrock MikeBrock is offline
MikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond repute
I think this is definitely the year to use mecanums. A lot of teams will have a solid performance if they use mecanums. I say go for it!
Unread 12-01-2012, 23:24
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
What's your reasoning?
The only pure mecanum team that's ever stood out to me was 2337's machine last year. Every year I see a multitude of mecanum teams that don't really implement them very well, drive very sluggishly, and get pushed around constantly.
Also, a lot of teams tend to shy away from mecanum teams when picking for eliminations if they are able to. Personally, if I'm a top 8 team trying to find a solid second pick at a regional and i'm presented with two identical robots in all aspects, but one has mecanum wheels and the other is the standard kitbot, I'm picking the 6 wheel, no question about it.
If you're a team that's thinking of using mecanum wheels, make sure you do it right. Talk to a team that's had a lot of success with mecanum, such as 2826 or 2337. they're some of teams I've seen up close that actually managed to stay competitive while using that type of drivetrain.
Unread 12-01-2012, 23:28
dtengineering's Avatar
AKA: Jason Brett
Not to rain on people's parades here, but.....[*]In the second video, the Mecanum's were having a very hard time getting up the bridge (not too sure how it helped Mecanum's case). If anything, it shows that carefully done programming will be required just for your drivetrain.[/list]Please take my criticism in a constructive manner, as I will do the same.
-Duke
I don't think you're raining on anyone's parade by providing practical advice based on your experience, however the intent of the video I posted was not to show that "it is easy to do", but rather that "it can be done", and (as you have correctly emphasized) to point out that software can make a huge difference in how mecanums behave.
In the bigger context, though, your experience with mecanum drives clearly shows. Every benefit provided by mecanums comes at a cost. Even the added mobility, which many see as a pure benefit, comes at the cost of additional driver training and practice driving time to fully utlize it.
The year we built mecanum the added complexities of our drive (and other mechanisms) meant that we did not have the final, working robot ready until about 2 hours before the FedEx truck arrived. It wasn't until the end of our second regional before our driver was truly able to intuitively take advantage of our increased mobility to deke out other robots. It was AWESOME when it worked... just beautiful, really... but until then we wasted a lot of time in pushing battles where our mecanum really didn't help.(Although it didn't hurt nearly as much as we had expected... we could hold ground with many robots and actually push some with 2 motor drives or poor gear choices.)
In our final year of competition we built a torquey 8 wd machine that could accelerate, stop, turn 90 degrees and accelerate in about the same amount of time that the mecanum could drive forward, then strafe sideways. It was an easy build/program (not that mecanums are particularly hard to program with the cRio), a top pushing machine that could "get air" off the bumps and, in the end... very close to as maneuverable as the mecanum.
But it wasn't as cool.
Duke has it right... there are lots of good reasons why mecanums aren't the best choice for this year's game... or for any year's game. But they do work, they CAN climb, and they are very, very cool.
Our mecanum robots competition life was over in a few months, but five years later I still have people asking me "what's with those wheels?"
If you haven't built/driven a mecanum, you owe it to yourself to try it at some point. Maybe this year...?
Jason
Unread 13-01-2012, 02:39
Originally Posted by AlecMataloni View Post
If you're a team that's thinking of using mecanum wheels, make sure you do it right. Talk to either 2826 or 2337. they're the only teams I've seen that actually managed to stay competitive while using that type of drivetrain.
Those teams would have been competitive because of what was on top of their drivetrain, not what the wheels were. 357 by all means is the mecanum expert, but they aren't as strong in other aspects of their robots each year as 2826 or 2337 are.
I can easily bet that if 111, 1114, 217, 148, or 254 used macanums they would still be highly competitive as usual.
Unread 23-01-2012, 01:48
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Here is our 2011 bot with mecanum going over the bridge. Keep in mind the driver was taking it very slow. Yes, there is some wheel spin but we had no real trouble with the bridge head on.
link
Unread 23-01-2012, 09:39
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
i highly doubt that it will work on the lexan key let alone the key
