Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 11-01-2012, 15:04
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Chassis Lift alternative, getting over barrier
A couple of ideas are rolling around in my head (yes, just a couple) about getting over the barrier.
The easiest seems to be a lift kit... but they're out of stock. Would a short section of KOP c-channel (~4") bolted below the chassis be strong enough to hold the wheels? It would raise the chassis from 3 3/8" clearance to 4 5/8" using 2011 8" wheels, plenty to go over the barrier. A skid plate of some sort might still be need to pop the wheel up a bit on approach.
We can't test it, and see if it works, but I'd like to hear some veteran opinions on the matter.
Unread 11-01-2012, 15:07
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Chassis Lift alternative, getting over barrier
Bend your own?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 11-01-2012, 15:09
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Our experience bending metal last year was miserable. I figured that since the c-channel already has consistent hole placement, and profile, it would make for a good quick replacement.
Unread 11-01-2012, 22:25
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Since the lift kit is out of stock as you say, reach out to other teams in your area. I'm sure some older teams have some left over from previous years & would be happy to donate/trade them.
Unread 11-01-2012, 22:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The easiest seems to be a lift kit... but they're out of stock. Would a short section of KOP c-channel (~4") bolted below the chassis be strong enough to hold the wheels? It would raise the chassis from 3 3/8" clearance to 4 5/8", plenty to go over the barrier. A skid plate of some sort might still be need to pop the wheel up a bit on approach.
Like this
======X===========================X=====
........==O==..................................... ........... ==O==
= is the frame
X is the normal axle position
O is the new axle position?
. is just something I had to put in to make my ascii art work.
I think that this would be just fine.
Good idea.
Joe J.
Team #88, TJ2
Unread 11-01-2012, 22:45
DonRotolo's Avatar
Back to humble
FRC #0832
6061-T6 is not meant to be bent, and it will want to crack. Try 5052-H32 instead, it bends beautifully (but machines poorly)
Unread 11-01-2012, 22:47
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I'm confused as to where you are getting the numbers for this. Is this with 8 inch wheels (instead of the KoP 6")?
We were hoping to give the robot a "lift kit" to get over the bump as well.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 11-01-2012, 23:14
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Sorry for not putting that originally. Yes the 8" wheels
Unread 11-01-2012, 23:19
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Has anyone considered using Tri star wheels for this purpose?
Unread 11-01-2012, 23:46
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Our team is repurposing some older Kit bot C-channel frames to do exactly as you propose.
Unread 13-01-2012, 00:08
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
No offense to your idea, but those wheels look insanely heavy.
Unread 13-01-2012, 01:12
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
If built right(meaning not overly big) they could easily weigh less than half of a 10" mecanum. They worked in 2004(340 & 1218).
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 13-01-2012, 01:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
296 also used them one year.
(And yes, they have indeed been considered.)
Unread 13-01-2012, 10:44
Guderian1511 Guderian1511 is offline
AKA: Matthew Mlodzienski
FRC #1511 (Rolling Thunder)
Team Role: Animator
Guderian1511 is an unknown quantity at this point
1511 is currently doing this with 8" AndyMark pneumatics, at least for our mock/proto chassis. I believe we figured that you would need additional spacers in-between the two c-channel segments, in order to fit hardware for the frame like screw heads over the barrier. We're currently shooting for 3/4 to 1" of clearance.
How much do the standard wheels wear down? That could possibly affect your spacing.
Unread 13-01-2012, 10:46
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
We did in 2004. Check out the link below!
http://www.chiefdelphi.com/media/photos/17077
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
