Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 12-01-2012, 00:01
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Tachometer using Retro-Reflective sensor
I saw this used in one of the FIRST robotics books and I was wondering specifically how someone would implement this?
Unread 12-01-2012, 00:29
Re: Tachometer using Retro-Reflective sensor
The tape is placed on a rotating object in segments. This allows a photo sensor aimed at the tape to alternately turn on and off at the segment rate effectively counting segments. Say there are eight transitions on a 6" diameter wheel, you might be able to resolve horizontal movement of the robot on the order of less than one inch per segment. More transitions gives you better accuracy. If you use two sensors you can actually determine direction as well as rotation distance.
Unread 12-01-2012, 00:31
baronep's Avatar
Student President
Ok. I was more interested in sensing speed rather than distance. Does anyone know how to implement the code for this? Is DMA involved? Periodic tasks? Interrupts?
Unread 12-01-2012, 00:35
It should be simple using the counter vis.
Unread 12-01-2012, 10:02
There's an example towards the bottom of the page here: http://team358.org/files/programming...2009-/LabVIEW/
Search fot "Tach"
