Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 10-01-2012, 19:44
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Workaround for E09 Classmate USB boot failure
Our team is one whose 2009 Classmate refuses to boot from the 2012 Driver Station Image USB provided in the KoP.
As a workaround, we cleaned a generic USB stick (an old Microcenter 16GB), copied all the contents of the KoP stick to it, and made it bootable using the Windows 7 AIK tools (bootsect /nt60). The Clasmate booted and re-imaged successfully from the generic USB stick.
Hope this helps....we found this process easier than doing the "clean and update" procedure previously posed on the FIRST website.
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 12-01-2012, 00:53
CJ1994 CJ1994 is offline
FRC #0753
CJ1994 is an unknown quantity at this point
Re: Workaround for E09 Classmate USB boot failure
THANK YOU, THANK YOU, THANK YOU!!!!! I will try this tomorrow and post results! We are having the same issue.
Unread 12-01-2012, 14:03
FRC #0753
Question Re: Workaround for E09 Classmate USB boot failure
Question: could you apply the "bootsect /nt60 X:" command to the image that FIRST gave us* or will this not work.
Side note: I have not been able to try this suggestion yet. I will post results later.
*All other people reading this, REMEMBER BACKUP, BACKUP, BACKUP before you modify anything that FIRST gave us!
Unread 12-01-2012, 17:27
FRC #0753
Ok tried this. It didn't work. What command did you use with bootsect.exe?
Thanks in advance
Unread 12-01-2012, 17:55
AKA: Ron R
Assuming the new generic USB stick is drive X:, the command "bootsect /nt60 X:" should work.
Make certain you start from a "clean" USB stick - use diskpart to "clean" the stick, then create a new primary partition on the stick, mark it active, and format it.
Then copy over the contents from the KoP USB stick.
Then use bootsect to make the USB bootable.
- Ron
Unread 12-01-2012, 19:43
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
ssirovica is an unknown quantity at this point
how do you copy it to the other "clean" disk
because i have a 8GB flash disk however it says i dont have enough space to copy it over
i need some help!! Thank you!!!!
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 12-01-2012, 19:47
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
FIRST released today a walk through on how to transfer the files from the damaged flash drive to a new flash drive that will fix the damaged boot sector.
-Michael Dessingue
Unread 12-01-2012, 21:02
ssirovica's Avatar
Programming Captain
AKA: Sasha Sirovica
Thank you so much!!! It works!!!
