Go to Post oooh tight leather bumpers...sexy! - Nuttyman54 [more]
Unread 12-01-2012, 01:33
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: Mecanum on the bridge?!
Originally Posted by Duke461 View Post
[*]It took a long time to get up that ramp. Too long.
Slippery surface, high CoG robot, early test. Our tests show it doesn't take nearly that long.
[*]1 out of 5 times that drivetrain will probably fall off, unless you go super slow, which in that case see Bullet point #2
The bridge has more than enough maneuvering room; if you fall off it's because you drove really badly.
[*]What happens if for some reason you can't go over the bridge that round?
Find me an opposing robot blocking your bridge and I will find you a nine-point technical foul. Besides, bridge traffic is likely negligible.
Mecanums will have an extremely hard time maneuvering the ridge.
Mecanums can have wheel guards and wedges built in, same as any drive.
[*]The material on that bridge was different than that of in the real game
But it had less friction.
[*]A preponderance of team's this year will have a strong hard pushing robot. Good luck scoring on one. It's not fun.
Score from the key.
